C4, Lt1, 1995
Old Oct 18, 2002 | 10:36 AM
DRAZEN's Avatar
DRAZEN
Default C4, Lt1, 1995
I'm C4, Lt1, 1995 owner! I bought my car with 14 000 miles and now it has 17000. I was changed engine oil and filter.
What else do I need to change?
Old Oct 18, 2002 | 10:52 AM
The Rex's Avatar
The Rex
Default Re: C4, Lt1, 1995 (DRAZEN)
I 'd recomend changing all the fluids. Flush the radiator & clean the "no mans land" portion of it, tran service, diff fluid, & fuel filter. I believe in over maintaining my vehichles. I know I'm **** about it (especially my Vette) but it can't hurt to take to well care of your car. :yesnod:
Old Oct 18, 2002 | 11:20 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
If it's got a ZF6, you don't need to touch it yet. I'd wait until 25-30K miles. GM claims it doesn't ever need to changed, but that isn't what the manufactuer of the tranny says. See this FAQ...
http://www.zf-group.com/am/pc/pt/ampcpt03.phtml :flag
Old Oct 18, 2002 | 01:09 PM
John Row's Avatar
John Row
I change the fuel filter, coolant, trans, diff and brake fluids every year (oil & filter every 3-4K) we do about 20K/yr. I know it's probably overkill, but we just turned 150K miles. It's not that expensive.
OTOH, I seem to add fluids to my 87 Honda whenever it runs dry :eek: It's got 187K.
[Modified by John Row, 11:15 AM 10/18/2002]
Old Oct 18, 2002 | 02:27 PM
pwrful c4's Avatar
pwrful c4
Default Re: C4, Lt1, 1995 (96 LTRex-4)
I AGREE ESPECIALLY BECAUSE OF THE YEAR. :smash:
Old Oct 18, 2002 | 02:55 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
the car is now 8 years old.
You dont know how the previous owner took car of it?
If not, I would suggest a change of ALL fluids, including coolant.
Air and fuel filter changes also should be considered seriously.
Old Oct 21, 2002 | 01:26 PM
DRAZEN's Avatar
DRAZEN
Default Re: C4, Lt1, 1995 (Phil-tha-Rush)
Thanks a lot, all of you!
Old Oct 21, 2002 | 10:17 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Old Oct 22, 2002 | 04:43 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
can't think of any more advice since it is 4am but wanted to welcome you to the Forum, and good choice on the year :cheers:
[Modified by Drewdog, 3:43 AM 10/22/2002]
Old Oct 22, 2002 | 05:08 AM
93 ragtop's Avatar
93 ragtop
Default Re: C4, Lt1, 1995 (Drewdog)
If it was mine, I would run a can of dry gas through the fuel tank as well. With only 14000 miles it has set a lot and the potential of condensation is high.
Old Oct 22, 2002 | 06:50 AM
DRAZEN's Avatar
DRAZEN
Default Re: C4, Lt1, 1995 (Red 86 4+3)
I've got one more problem. Here in Croatia is no corvette service and I have to chenge plugs and fluids alone. Can anybody tell me what is the best way to do it?!
P. S. Changing plugs looks very complicated!
Old Oct 22, 2002 | 07:16 AM
Sliding's Avatar
Sliding
Hi Drazen!
Good to see You here in forum.
Old Oct 22, 2002 | 04:10 PM
mikey's Avatar
mikey
everyone has pretty much said what needs to be said, but i'll add just one note on low mileage cars that are older..
make sure you thoroughly flush the coolant system, all of it! remove the knock sensors from the block and drain everything.. don't just drain the radiator.. chances are you'll find a significant amount of rust due to the large amounts of idle / storage time..
run lots of water through the block before re-installing the sensors and refilling with coolant..
Old Oct 23, 2002 | 01:55 PM
DRAZEN's Avatar
DRAZEN
Default Re: C4, Lt1, 1995 (mikey)
Where are the knock sensors situated?
Old Oct 23, 2002 | 02:22 PM
Steel Blue 91's Avatar
Steel Blue 91
Pretty straight forward but a real pain. You'll need swivels, extensions, beer and patience, lots of patience. Remove the inner fender around the front suspension on both sides. The first time you do it will take some time. After that, about 40 min. or so. Do a search. There are plenty of threads on this subject.
BTW Welcome to the fourm.
To C4, Lt1, 1995
