ASR Service light
Old May 22, 2018 | 10:57 AM
Woody63's Avatar
Woody63
2nd Gear
Default ASR Service light
I have a 92 Corvette and when I start it up the Srvice ASR light comes on, as the car warms up it will surge a few times and then smooth out but the Service Engine Soon light comes on. Not sure if these are related or not but they seemed to have started happening about the same time. I have researched the issue and most claimed the wires going to the rear speed sensors may have had the sheilding cut and shorting out, checked this and no issue there. I ran the codes and got 1-C12, 4- H74 & H22, 9-H64. I cleared all codes and checked again and C12 and H64 will not clear. Any help would be greatly appreciated.
Old May 22, 2018 | 01:14 PM
JimLentz's Avatar
JimLentz
If you start getting random codes, A/C stop working for a bit or engine stalls 2 seconds after starting intermittently it might indicate ECM problems.
Old May 22, 2018 | 10:11 PM
Miguel93's Avatar
Miguel93
3rd Gear
I have an frequent service ASR light too (1993). Drives me bananas! I see sys flash next to the speedo whenever it comes on while driving. This means a code just got set, but the codes that get set are not related to the traction control (ASR) or ABS. If it stays on after the key-on bulb check, the car won't start so sometimes I have to key off and on repeatedly till it clears just to get it to start. Worried it's the CCM or the PCM. As you say, any help would be greatly appreciated!
Old May 23, 2018 | 07:25 AM
JimLentz's Avatar
JimLentz
The ECM for 1992 and 1993 are the same and a fairly common problem is they get intermittent internal solder connections. I had similar problems with my '92 and after having my ECM rebuilt I no longer have any issues.
Old May 31, 2018 | 07:00 PM
Miguel93's Avatar
Miguel93
3rd Gear
Thanks~ any recommendations for a rebuilder?
Old May 31, 2018 | 07:06 PM
JimLentz's Avatar
JimLentz
I used SIA Electronics in southern Illinois and it took about a week to get the ECM back. If you send it in to them be sure to remove the MEMCAL first.
http://siaelec.com/
To ASR Service light
