Flow numbers for ported D port heads?
Old Oct 18, 2002 | 07:56 PM
LD85's Avatar
LD85
Default Flow numbers for ported D port heads?
Anyone got some? How can can they be? I just bought some 1988 D-ports.
[Modified by ld85, 6:57 PM 10/18/2002]
Old Oct 18, 2002 | 11:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Flow numbers for ported D port heads? (ld85)
Did you also find data on the results of pocket porting, etc?
There's been some posted here and TPIS "Insider Hints" also has some.
Old Oct 19, 2002 | 12:07 AM
gtsyellow's Avatar
gtsyellow
did you run across the post i did, search my usename & you should find a VERY good D-port post.
Old Oct 19, 2002 | 09:49 AM
LD85's Avatar
LD85
Default Re: Flow numbers for ported D port heads? (gtsyellow)
GTS, yes I did find that post! Thanks!
I think the D-ports I picked up once fully P&P'd are going to make a major improvement over my cast iron heads on my 85. :cool:
To Flow numbers for ported D port heads?
