correct 6 speed fluid ?
Old Oct 18, 2002 | 08:35 PM
Achille's Avatar
Achille
Default correct 6 speed fluid ?
What is the correct fluid for a 1990 6-speed manual trans? :flag
Old Oct 18, 2002 | 10:36 PM
keekster's Avatar
keekster
Default Re: correct 6 speed fluid ? (Achille)
Go to the dealer or BMW M5 synthetic Motor oil
Old Oct 18, 2002 | 11:22 PM
don hall's Avatar
don hall
[Modified by Oldman, 11:15 AM 10/19/2002]
Old Oct 19, 2002 | 12:10 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: correct 6 speed fluid ? (Oldman)
GM manual transaxel fluid 1052931. See tech tip at top of main forum page.
Old Oct 19, 2002 | 02:43 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Re: correct 6 speed fluid ? (PeteL)
:yesnod: :yesnod: :cheers:
Old Oct 19, 2002 | 11:32 AM
GS345's Avatar
GS345
St. Jude Donor '11
Default Re: correct 6 speed fluid ? (keekster)
:yesnod: :yesnod:
Old Oct 19, 2002 | 01:39 PM
fnseeker's Avatar
fnseeker
The correct fluid is 5/30 in either standard or synthetic. The dealer has this as well as a bmw dealer. Or if you can find a castrol dealer that can get the 5/30 castrol. Do not play games with other fluids. The results over the life of your trans will come back to find you. A so called trans expert in seattle changed the fluid in mine to 90/120 valvoline. After the car warmed up the grease would turn to foam. Try to shift that.! It took two changings of the grease to get the system clean. Hope this helps.
Old Oct 19, 2002 | 02:43 PM
Rearview's Avatar
Rearview
Default Re: correct 6 speed fluid ? (fnseeker)
Not just any 5w30, GM has a special GL-3 5w30 for the ZF6. Also, I do believe the BMW M5 tranny fluid is a synthetic Castrol 10w60 (I could be wrong) but either way, when you ask for it be sure to specify that GM part number from above or make sure you are getting the M5 transmission oil. :cheers:
Old Oct 19, 2002 | 04:06 PM
Silver89's Avatar
Silver89
Default Re: correct 6 speed fluid ? (Rearview)
GM P/N 1052931 or
BMW P/N 07510009420
I believe the BMW oil is the motor oil for M5's, so if you ask for the tranny fluid, you might get the wrong one. In any case, use the part number above
To correct 6 speed fluid ?
