Roller Rockers
Old Oct 19, 2002 | 12:20 AM
Stingray1970's Avatar
Stingray1970
Default Roller Rockers
Will 1.5 roller rockers fit under stock L98 valve covers? :seeya
Old Oct 19, 2002 | 12:35 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Roller Rockers (Stingray1970)
That depends on if the L98 valve covers have drip tabs or not.
You might already know this, but the rocker ratio doesn't have much to do with it. If brand X 1.5 rockers will clear the covers than brand x 1.6's will also clear. If 1.5's clear and 1.6's don't on the same brand then you are running some pretty tight tolerances on the 1.5's, something you would want to correct anyway.
Old Oct 19, 2002 | 01:01 AM
atotalnincompoop's Avatar
atotalnincompoop
I have 1.6 proform, self aligning full roller rockers under my stock valve covers, no problems at all :cheers:
Old Oct 19, 2002 | 01:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe your '90 L98 has the same valve covers as my '88; I had to trim the drip tabs and narrow the center bolt posts to clear the 1.6:1 ProMagnums.
Old Oct 19, 2002 | 01:43 AM
paulie's Avatar
paulie
I have crower 1.5's on my 85, no problems, there great :seeya
To Roller Rockers
