85 bosch injector number
Old May 29, 2018 | 09:00 PM
Bryan B's Avatar
Bryan B
Default 85 bosch injector number
Can anyone tell me the bosch injector number for an 85 vette stock
Old May 29, 2018 | 09:59 PM
aklim's Avatar
aklim
https://fuelinjectorconnection.com/c...3-injector-set
Old May 30, 2018 | 12:55 AM
Bryan B's Avatar
Bryan B
Thanks, really appreciate the information..
The old injectors were Bosch # 0 280 150 223, and I do not think they are the right injectors for the 85 vette.
Old May 30, 2018 | 01:08 AM
aklim's Avatar
aklim
http://m.fuelinjector.citymaker.com/Fuel_Injector_Flow_Rates.html
According to the chart you have 21.35 pph. 24 isn't that bad to have If you have original ones, they are probably having some built up reside so the reman ones would better Also if you are doing them, have the cold start injector services while you are there
Old May 30, 2018 | 01:12 AM
Bryan B's Avatar
Bryan B
would I have to do anything with my stock fuel pressure regulator,or just plug them in and turn the key
Old May 30, 2018 | 01:17 AM
aklim's Avatar
aklim
I'd definitely change it The rubber is pretty old. Ask Jon. He will have the parts. Probably send him your cold start injector and have him service it and send back 8 tested and clean Reman units and gaskets Might as well take the IAC, IAC housing and top plate off the throttle body, clean with brake cleaner, reassemble with fresh gaskets Also do the TB coolant bypass at the same time
Old May 30, 2018 | 01:25 AM
Bryan B's Avatar
Bryan B
Jon is with fuel injector connection?
Old May 30, 2018 | 01:26 AM
aklim's Avatar
aklim
Yes, why?
Old May 30, 2018 | 01:30 AM
Bryan B's Avatar
Bryan B
Yes, why?
just making sure you were not referring to a form member. Thank you, really appreciate your help... I will chat with Jon tomorrow morning
To 85 bosch injector number
