Winter Storage
Old Oct 19, 2002 | 01:00 PM
sherpabob's Avatar
sherpabob
Cruising
Default Winter Storage
I was thinking about putting it up on jack stands this year and wanted to get an idea of what everyone else does. In the past I just let it sit on the tires and took it out every two weeks to rotate where the tires were resting.
Old Oct 19, 2002 | 02:31 PM
1-MORTOY's Avatar
1-MORTOY
Default Re: Winter Storage (sherpabob)
I park all my winter stored vehicals/trailers on 2" thick, 2 ft square panels of StyroFoam blue insulation. This stuff is fairly hard but it forms nicely to the curve of the tires so they don't flat spot. You just have to cut a slope on one side so you can drive up easily.
Its a lot easier to do than jacking and blocking the suspension plus you also don't have to move the car around either. Another benefit is if you did have to move the car in an emergency (fire/flood etc) you just crank it up and you're on the road.
Old Oct 19, 2002 | 02:58 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Don't forget the additive to avoid fuel deterioration over a long stroage period where you don't start her up.
Old Oct 20, 2002 | 11:26 AM
6spd89's Avatar
6spd89
Default Re: Winter Storage (65Z01)
I use this stuff from NAPA called SEAFOAM for my gas tank. This stuff
is the poopie IMO.I started putting in my 97p/u and it keeps the throttle
blades alot cleaner on the underside.I think one can does 20 gallons or so.
About $5 a can.
Matt
Old Oct 20, 2002 | 12:34 PM
Rich B.'s Avatar
Rich B.
I use StaBil, but I start it up every month, at least. I keep it reg'd & insured year-round. Trickle-charge the batt every month also.
Flat-spotting tires is the least of my concerns. (OEM GS-C's; lots of dry-rot cracks, but no leaks...Kumho's are on my Winter list).
Old Oct 20, 2002 | 01:23 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: Winter Storage (Rich B.)
I have heard that starting them in the winter is good/bad saves the seals from drying out but also causes condensation in exaust, transmission if not driven around now this is just what i read.. Try a bubble .. Ecklers has them
[Modified by Ericthewolf, 6:24 AM 10/20/2002]
To Winter Storage
