AC switch not working or relay?
Old Oct 19, 2002 | 06:11 PM
shcuck's Avatar
shcuck
Default AC switch not working or relay?
I just came across an issue with my AC. When I turn the switch to HIGH, the blower works fine, but in any other of the positions, it does not work (Low, Med1 ,Med2).
Is this a problem with the control switch itself, or is there a relay somewhere. The reason I ask, is becuase on the wire diagram, I noticed that the HIGH setting goes directly you the blower, and the other 3 positions, go to a dotted lined square that continues to the blower.
Any help with this would be great. :)
shcuck
[Modified by shcuck, 4:12 PM 10/19/2002]
Old Oct 19, 2002 | 07:34 PM
bogus's Avatar
bogus
Default Re: AC switch not working or relay? (shcuck)
that sounds like the little box thingy has died...
have you taken the switch out and cleaned it???
Old Oct 25, 2002 | 12:40 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Get the system recharged...this will cure the problem....EASY Fix... :D :D
To AC switch not working or relay?
