OE Concept Wheels vs. A-Molds
Old Oct 19, 2002 | 07:47 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default OE Concept Wheels vs. A-Molds
Hi all, I've been trying to purchase a new set of "ZR1 style" five spokes for some time now, and have run into a decision to make. I wanted AFS wheels, but the wait time is ridiculous. SO, here are the choices:
Aftermarket ZR1 wheels (OE Concept wheels- http://www.oeconcepts.com)
OR
Factory A-Mold wheels [black GS wheels sprayed silver]
I know that the factory A-Molds are lighter, but will they also balance better? What other differences are there??
I'm trying to justify the price- $1000 [oe concept] vs. $1400 [factory] comparitively
Many thanks! :cheers:
Old Oct 19, 2002 | 07:51 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: OE Concept Wheels vs. A-Molds (365ZUM)
I would not run AFS they are heavy, build quality isn't quite as good (finish). I cracked my AFS and still don't know how. :confused: Guess it was construction on I85, but nothing I haven't done with factory or Forgelines.
Old Oct 19, 2002 | 08:20 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: OE Concept Wheels vs. A-Molds (93Polo)
I have a set of OE rims. Havn't had a problem with them yet. They weight 23lbs & 25lbs. I don't think it matters if they are balanced. Because you need tires to balance them corretly.
Old Oct 19, 2002 | 08:24 PM
365ZUM's Avatar
365ZUM
Default Re: OE Concept Wheels vs. A-Molds (Coupe89)
I think that weight distribution (balance) is an indication of build quality.
Old Oct 19, 2002 | 08:29 PM
CowboyNVette's Avatar
CowboyNVette
Old Oct 19, 2002 | 09:04 PM
95AquaC4's Avatar
95AquaC4
If you don't mind a slight downsize in the rear, you can get a full set of A-molds from SLP for about $700. That's the route I took. All 4 17x9. 1/2 inch smaller than stock in the rear, 1/2 inch bigger in front. I am no Richard Petty, I feel no difference!! Check out www.slponline.com
What are the wheels on there??
[Modified by 95AquaC4, 8:06 PM 10/19/2002]
Old Oct 19, 2002 | 09:10 PM
365ZUM's Avatar
365ZUM
Default Re: OE Concept Wheels vs. A-Molds (95AquaC4)
[QUOTE]If you don't mind a slight downsize in the rear, you can get a full set of A-molds from SLP for about $700. That's the route I took. All 4 17x9. 1/2 inch smaller than stock in the rear, 1/2 inch bigger in front. I am no Richard Petty, I feel no difference!! Check out www.slponline.com
What are the wheels on there??[QUOTE]
Thanks Aqua, but the reason I am making the change is to go to 11" wheels in the rear.
I currently have the factory A-mold CE wheels- in CE sizes however...
They will be going up for sale soon, if anyone is interested.
[Modified by 365ZUM, 8:10 PM 10/19/2002]
Old Oct 19, 2002 | 09:11 PM
95AquaC4's Avatar
95AquaC4
I see. Sounds like a good idea!! :cheers:
To OE Concept Wheels vs. A-Molds
