1985 Corvette Oil Loss
Old Jun 8, 2018 | 05:58 PM
rjdeppler's Avatar
rjdeppler
4th Gear
Default 1985 Corvette Oil Loss
Lost all oil in my car today in less the 5 minutes. Leak is coming from over the oil filter, gusher variety, but I can not pinpoint the source. Seems like a line broke. Any ideas what could be happening?
Old Jun 8, 2018 | 06:04 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Well, first - an '85 is a C4, so you are on the wrong forum.
Was the oil filter just changed? If yes, you probably have a double gasket (gasket from old filter still on the block) or a defective new filter.
If no, it is less likely to be the filter, but not impossible. Not sure of there are oil lines on a C4 in that general area or not.
Have you looked for the source?
Old Jun 8, 2018 | 06:19 PM
rjdeppler's Avatar
rjdeppler
4th Gear
I clicked on C4 but mouse was a little jumpy...............Checked all of your suggestions before posting. Looked for an hour under the car with no luck but lots of oil flow running out when the engine was on. Ran out of oil to continue today. You would think a stream that size would be easily found, but with the tight quarters and all the stuff in the area, not that easy.
Old Jun 8, 2018 | 06:23 PM
glbeauchamp's Avatar
glbeauchamp
That sounds like the most likely explanation..
Old Jun 8, 2018 | 06:53 PM
zeevette's Avatar
zeevette
It's a C4 cry for help.
Old Jun 8, 2018 | 08:12 PM
DDaaryl's Avatar
DDaaryl
seen it happen
Old Jun 8, 2018 | 08:13 PM
Moved to C4 Tech.
Old Jun 9, 2018 | 09:40 AM
SG Lou's Avatar
SG Lou
My money is on the forgotten OF gasket as well
Old Jun 9, 2018 | 09:41 AM
John A. Marker's Avatar
John A. Marker
Just posted a reply in the General Section. Check oil sending unit on the back of the block between the distributor and drivers side head. Picture in other post.
To 1985 Corvette Oil Loss
