So I noticed today while cruising around town, ambient temp at 89 fahrenheit. I wasn't running the AC and temps came up 228, which on a 93, is when the primary fan is turned on. Once on, it turns off at around 215. Well today, it got up to 230 and stayed there(just staying stopped in traffic), I could hear the fan running. I doubt, hope, the head gasket isn't bad. Car has 84k miles. Going down the highway, temp comes down quick.
I cleaned between the condenser and radiator last year.
Any ideas?
1 fan or 'both' fans? Maybe you do the ECT sensor for the ECM for purely maintenance reasons, maybe the resistance of the ECT has 'wandered'. Use the 6E3-C-12 section of the FSM to confirm fan operation. '93 was 1st year for MAXI Fuses. ECT ever replaced?
You could check the ECT resistance using either the FSM references or maybe this Delphi reference guide:
Yes, ECT was replaced about two years ago. At 228, it turns the primary fan on only. If it goes to 236, then it turns on the secondary fan.
You didn't mention checking for 'both' fan operation. You only mention hearing 'fan running'.
A friend used a ECT connector and a longer fabricated pig-tail with female terminals that enable him to unplug the ECT on all cars that use this type ECT to do resistance checks with his DMM. If a car is at his shop a couple days he makes it a habit to check ECT with car @ full 'cold'. A check @ full cold or even after shut down with 'KEY-OFF' you won't set DTC.
I'll check fan(s) operation later today. I can guarantee they both work. Car runs damn well, I had a bad ECT on this car and it ran bad. I datalog with this car. And what the datalog tells me vs what the car digital temp display tells me, they say the same numbers. I have checked resistance this morning, and it is certainly in spec.
