Help Needed with Fuel Return Line
Old Jun 11, 2018 | 09:02 PM
Lawman31's Avatar
Lawman31
Default Help Needed with Fuel Return Line
My mechanic told me that he didn't think that this connection was correct since the line just pushes in without any type of nut to hold it in. Can you guys look at this picture and let me know what this is supposed to look like, of if this is correct? It's a 1994 Coupe Automatic. I see the threads, so I presume something is missing.
If possible, can you post pictures of the correct configuration if mine is wrong?
Old Jun 11, 2018 | 09:12 PM
WVZR-1's Avatar
WVZR-1
This is a '94+ FPR arrangement
Here's a link that will take you to a GM SPO Parts Catalog that might help you. I do believe I've bought the retainer separately in the past but I've no idea where!! No idea. If I recall I'll post back.
https://www.wholesalegmpartsonline.c...rimLevel=25296
Old Jun 11, 2018 | 11:40 PM
Lawman31's Avatar
Lawman31
Attachment 48293679
I see from this diagram that I need the part listed in the diagram as #14, but I can't seem to find out from the link how to find the actual GM part number to try and order one somewhere. Does anyone know how to find this part number?
Thx.
Old Jun 11, 2018 | 11:54 PM
Lawman31's Avatar
Lawman31
Thx.
Hey guys, is this what i need here?
Old Jun 11, 2018 | 11:56 PM
Lawman31's Avatar
Lawman31
Or perhaps this one??
Old Jun 12, 2018 | 12:23 AM
Joe C's Avatar
Joe C
i'm thinking the clip is part of a GM repair "kit" and most likely not sold as a separate part, thus no individual listing for #14. the kit is listed as "no longer available". this is a long shot - try GP Sorensen, p/n 800-9410 -
fairly sure that clip is used across several German lines - finding the correct part number would be the problem. the above Sorensen part shows availabliy from autozone. good luck in your search. sometimes parts like this can be a real challenge -
Old Jun 12, 2018 | 02:55 AM
WVZR-1's Avatar
WVZR-1
Try a BWD 28416 from maybe Advance or any other local AP store. You could also cannibalize any '94+4.3W, 5.7P in F-body or full-size car. If the BWD 28416 does work ---- post back. My NAPA store has that as # CRB 217461
My friend didn't remember where we got it either but mentioned the 'cannibalization'.
Old Jun 12, 2018 | 09:27 AM
Lawman31's Avatar
Lawman31
Hey guys... The pictures of the clips I posted above are easily available on eBay, I just needed to know if they were correct. The one part number given from Sorensen 800-9410 brings up the same picture I posted.
Is what I have in the picture the correct part?
Thx.
Old Jun 12, 2018 | 09:37 AM
WVZR-1's Avatar
WVZR-1
Thx.
If I had 'known' I would have told you - I don't know why you'd consider eBay. I gave you 2 part #'s you should be able to buy/try local!!!
From the looks of your return line (THE KINK) I'd say you maybe consider more than just the retainer. For sure an o-ring!
To Help Needed with Fuel Return Line
