I noiticed when on auto or manual the car would surge with ac on. I charged it to the correct suction pressure; same problem. at idle and even whey at steady 2000 rpm it the ac clutch doesnt cycle.. any ideas?
So when you turn on the ac, clutch doesn't engage, motor surges, and I assume no cold air.
Sounds like the computer is compensating for a load that isn't happening.
What year have you got?
Cool air is coming out of the vents but a feel a very slight surge as though th ac is cycling. It would seem to me it wouldnt be felt in a 300hp v8? Im worried that the clutch of the ac is getting hot and releasing then engaging. I had this happen in my 99 f250 and all I had to do was remove a shim and it solved it.. but in that case cooling would stop inside the pass compartment and then come back on..
So I guess Im asking if a very very slight surge of power loss and gain is felt while driving my 96 corvette is normal.
At idle I see the clutch is engaged all of the time when its 95f ambient.
Well.. its not normal.. It surges with great frequency and then at about 75mph after about 5 min it stopped..blew edit: WARM air. then after awhile I decided to turn it off and put it back in auto mode.. started to blow cold air and surge with frequency again.. anyone?
Well now it sounds like its just low on refrigerant.
On the rare chance the evap core is not sealed to the case, go run the car and the ac, then without shutting the car or the ac off, open the hood and see if you have frost on the low side lines.
I just charged it but will check again and also do a subcool test on it and see what I see. I think its a bad pressure sensor either low or high side.
Just make sure you notice if you have heavy frost on the low side lines. I had a 95 model car while back that sort of did what you are describing, it was full of refrigerant, and it would never really get very cold. Sometimes the compressor would cycle somewhat erratically, and if you turned the system off, then restarted it a few minutes later it would seem to cure itself for a short amount of time before reverting back to not very cold air and the compressor cycling again. Several different people tried to fix this car but never could figure out the problem. Ultimately I noticed something that others did not, that being frost on the low side lines all the way to the compressor. The refrigerant was not evaporating in the evap core, because the seal around the core had come apart and the blower motor air was going around the evap core.
