Ac problem continues
Old Jun 25, 2018 | 09:50 PM
Bigal07's Avatar
Bigal07
Cruising
Default Ac problem continues
Heater control wasn't working due to blown fuse. Narrowed it down to the pressure transducer (switch on the smaller of the ac lines). Changed it and fuse didn't blow. After a bit I tried getting the ac to work. Was adding refrigerant and fuse blew. Tried another fuse with the same result. If I unplug the transducer everything except the ac works and fuse doesn't blow. Anyone have any idea where I go from here?
Old Jun 25, 2018 | 10:31 PM
PatternDayTrader's Avatar
PatternDayTrader
What yr car
Old Jun 25, 2018 | 11:10 PM
Bigal07's Avatar
Bigal07
Cruising
And here I thought I was thorough. Its a 1992
Old Jun 26, 2018 | 12:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
How were the low/hi side pressures and what was ambient temp.?
Old Jun 26, 2018 | 06:33 AM
Bigal07's Avatar
Bigal07
Cruising
Temp was mid 70s. Pressures unknown.
Old Jun 26, 2018 | 08:32 AM
65Z01's Avatar
65Z01
Does the coolant fan come on before the (AC) Fuse blows?
Old Jun 26, 2018 | 11:20 AM
Bigal07's Avatar
Bigal07
Cruising
Fuse blows as soon as I change control panel setting to any position other than off.
Old Jun 26, 2018 | 11:39 AM
PatternDayTrader
Its virtually certain you have a short in the power feed to the compressor.
To Ac problem continues
