hub replacment Please help
Old Oct 21, 2002 | 09:11 AM
The Hobbit's Avatar
The Hobbit
Default hub replacment Please help
I have just ordered all 4 wheel bearings for my 86 vert (gulp) Can anyone give me some general tips on changing the hubs.
How do the ABS sensors interact with the front and rear hubs? Do I need to remove the sensors, if so how? I looked at the rear this weekend and undid the sensor clamp on the carrier, but the sensor did not budge. Have I missed something or do I need to use force to remove them?
According to the Haynes manual you need to remove the whole rear carrier, but looking at it looks as if you should be able to remove the hub without this, has any body tried this?
What sizes is the nut on the drive shaft and the star bolts on the hubs?
Thanks in advance for your help, its needed.
Old Oct 21, 2002 | 09:24 AM
chucks88's Avatar
chucks88
Default Re: hub replacment Please help (The Hobbit)
I've done this a couple of times on the rears only. I did not have to remove my drive axels. removing the shocks allowed for more room however. In the rear you have to jack the car up fairly high in order to break those 3 T55 bolts behind the knuckle. You should plan on spraying the hell out of them and be prepared to throw some heat on the knuckle to help break loose the bolts. Whos' bearing/hubs did you buy. I had to replace a CR (Chicago Rawhide) after only about 2,500K. Pep boys replaced it with an SKF unit which by the way is the same one NAPA sells. Breaking the 3 bolts loose is the toughest part.
Old Oct 21, 2002 | 09:35 AM
The Hobbit's Avatar
The Hobbit
Default Re: hub replacment Please help (chucks88)
Thanks for the info, not sure yet what make the hubs are, its not that easy to get a choice in the UK.
Again thanks for the info. All other comments more than welcome
Old Oct 21, 2002 | 09:46 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I've replaced the fronts on a 96 and a 88... You need to removed the caliper, rotor, then just remove the 4 bolts that hold the hub to the knuckle... You don't have to touch the speedo sensor.
The rears I just jacked up the car, one side, and removed the wheel. removed the cotter pin, mounted wheel, and lowered the car. Break the large spindle nut while the car is on the ground to keep pressure off the drivetrain. Then jack the car back up, and remove the wheel... I didn't remove the half shaft or the shocks. Just turn the half shaft so you can fit the socket in there and remove the three bolts. The front is easy and the back just takes a lot of time.
Old Oct 21, 2002 | 09:56 AM
The Hobbit's Avatar
The Hobbit
Default Re: hub replacment Please help (Bluewasp)
Thanks very much all of this help is very much appreciated
Old Oct 21, 2002 | 10:01 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I have pics of my rear bearing install at home. I'll post them again.
Old Oct 21, 2002 | 10:04 AM
bac22's Avatar
bac22
I just replaced the hub assembly on my truck. I know apples and oranges when compared to a vette, but I wanted to make you aware that you may need a either a slider hammer or a 3 arm puller. On my truck I needed to use a slide hammer with a flange adapter to get the hub assembly out. It was rusted in pretty good. Fortunatly Autozone here loans out tools so I didn't have to buy an special tools. Otherwise the job itself was pretty easy.
Just an FYI.
Old Oct 21, 2002 | 10:05 AM
The Hobbit's Avatar
The Hobbit
Default Re: hub replacment Please help (bac22)
Thanks I will look into finding one
Old Oct 21, 2002 | 10:07 AM
ittlfly's Avatar
ittlfly
If your's is the same as my 92, you'll need a 36mm socket to remove the spindle nut.
Good luck
Old Oct 23, 2002 | 08:51 AM
The Hobbit's Avatar
The Hobbit
Default Re: hub replacment Please help (ittlfly)
Thanks for all the help, my dealer is now asking if I have a spicer 36-ica or 44-ica? anybody have any idea what he is talking about ??
Old Oct 23, 2002 | 09:35 AM
chucks88's Avatar
chucks88
Dana 36 or Dana 44 possibly. But I don't know why that would matter
Old Oct 23, 2002 | 10:02 AM
ittlfly's Avatar
ittlfly
To hub replacment Please help
