sway bar question
Old Jun 29, 2018 | 04:09 PM
gnj3963's Avatar
gnj3963
Default sway bar question
hey, Can someone tell me if the front swaybar on 1984 c4 should be able to move freely up and down when the end links are disconnected.
Just replaced bushings with polys and grease but the bar is extremely tight. I read a couple posts. Some saying its not supposed to move and others saying it is not supposed to move.
any help would b appreciated.
Old Jun 29, 2018 | 05:24 PM
81c3's Avatar
81c3
If the end links arent attached, it will move... Its ok if its tight as long as youre sure the bushing size matches the bar size.
Old Jun 29, 2018 | 07:04 PM
ex-x-fire's Avatar
ex-x-fire
Yes it should move, if it doesn't then its acting like a second spring.
Old Jun 30, 2018 | 04:36 AM
blackozvet's Avatar
blackozvet
depends how strong you are !
if its old bushes it will move freely, if its new poly bushes then it will be tight. Make sure you lube them inside.
its the hundreds of pounds of spring rate at the swaybar arm that move the bar inside the bushing - not your arms.
but like xxfire said if its too tight it starts to add spring rate - but thats probably not a bad thing if youve got an old stock bar. Some racers actually use clamping on the bushing to change the swaybar rate.
Old Jun 30, 2018 | 01:09 PM
gnj3963's Avatar
gnj3963
Thanks for your help..I read somewhere people placing spacers in between the U bracket and the top plate to reduce load on the bushings..I tried that and the car sat a bit lower and the suspension felt like it had more travel..Not sure about this being a good thing i removed the spacers (about .25) and put it back to original way and the suspension is definitly more stiff this way..
Any input on this?
Old Jul 1, 2018 | 04:52 AM
64Scout's Avatar
64Scout
Pretty sure I read that too. I thought it was on this thread https://www.corvetteforum.com/forums/autocrossing-and-roadracing/4152743-c4-sway-bars-do-they-really-work.html but skimming through it I don't see it there.
Old Jul 1, 2018 | 06:45 PM
gnj3963's Avatar
gnj3963
thanx for that..cant find what i saw but good info
To sway bar question
