still have rough idle
Old Jul 2, 2018 | 03:07 PM
84Whitebird's Avatar
84Whitebird
Default still have rough idle
After putting in plugs, plug wires, cap, rotor, Ignition module, cleaning and setting the IAC valves, putting on a new TPS and setting that. My '84 still has a rough unstable idle. No vacuum leaks found either. Driving me crazy because it idled fine before I put new parts on.
Old Jul 2, 2018 | 03:11 PM
Dt86's Avatar
Dt86
Double check the spark plug wires.
Old Jul 2, 2018 | 03:19 PM
84Whitebird
That is going to be my next step. They were "cut to fit" like I've used a lot before. May not have one seated right or a connector pulled loose putting them in. Never know. I do know the new TPS woke that engine UP. much stronger now.
Old Jul 2, 2018 | 05:21 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Have you checked your fuel pressure recently? You will need a minimum of 11 for your engine to run right.
To still have rough idle
