speedometer incorrect
Old Jul 2, 2018 | 04:20 PM
bseif1122's Avatar
bseif1122
3rd Gear
Default speedometer incorrect
I have a 1990 ZR1 vette with a ZF 6 speed manual tranny. rear differential gears have been changed to 4.10 ratio. my speedometer is off and cannot be corrected by using OEM speedo gears. it has electronic speedometer with the sensor that is installed into extension housing. is there a electronic "cheater" module available that I could install that will adjust speedo to correct speed. or does anyone know of any places to get drive and driven speedo sensor gears to correct the speedometer.
Old Jul 2, 2018 | 04:37 PM
TheBlaster9001's Avatar
TheBlaster9001
A bit expensive, and I can't speak for how well it works, but Ecklers sells one.
https://www.ecklerscorvette.com/corv...CABEgJjm_D_BwE
Old Jul 2, 2018 | 04:54 PM
bseif1122's Avatar
bseif1122
3rd Gear
Thanks! that's exactly what I was hoping to find. I'll give that a try
Old Jul 6, 2018 | 01:41 AM
VenkmanP's Avatar
VenkmanP
Found this:
https://www.emracingshop.com/product...n-gears-manual
By reading old posts like these:
https://www.corvetteforum.com/forums...or-4-10-a.html
https://www.corvetteforum.com/forums...eedo-gear.html
That I found by doing this:
https://www.google.com/search?q=spee...=1686&bih=1244
To speedometer incorrect
