Runs rough after plug wire change
Old Oct 21, 2002 | 03:57 PM
Reneiria's Avatar
Reneiria
Default Runs rough after plug wire change
Just changed my plug wires and now the car runs rough as a cobb. It starts but back fires a bit and runs VERY rich. When I get some more light, I'll verify my wire paths and make sure I didn't cross any wires. Can someone give me the wire layout for the opti? I have one from another thread I used but it could be wrong. Also.... can I expect the car to run rough while it "re-learns" its settings (I disconnected the battery when I replaced the wires) :seeya
Old Oct 21, 2002 | 04:10 PM
Yellow95's Avatar
Yellow95
Default Re: Runs rough after plug wire change (Reneiria)
When I changed mine, I disconnected the battery and there was no 're-learn' time. I don't have my book with me now, so I don't have the wire layout.
Old Oct 21, 2002 | 05:14 PM
DRAGRACR's Avatar
DRAGRACR
I have crossed wires before and it ran just the same as you are describing.
the opti diagram is as follows : looking at the front of the motor to the left side of the opti, and starting at the top is 4,6,8,2 and the right side from top is 5,3,7,1. Hope this helps. :seeya
Old Oct 21, 2002 | 05:18 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Here is a link to the wires laid out.
The top is the driver's side and bottom is the passenger's side. The firing order of the opti spark is in my Helm's manual at home. Perhap this picture helps some.
http://temp.corvetteforum.net/c4/tmezger/wires_b.jpg
Old Oct 22, 2002 | 03:58 AM
Reneiria's Avatar
Reneiria
Default Re: Runs rough after plug wire change (DRAGRACR)
I have crossed wires before and it ran just the same as you are describing. the opti diagram is as follows : looking at the front of the motor to the left side of the opti, and starting at the top is 4,6,8,2 and the right side from top is 5,3,7,1. Hope this helps. :seeya
Thanks. :D I'll take a look this evening sometime. If I got a pair of wires crossed, I sure hope it's on the passenger side!! :cry
Old Oct 22, 2002 | 07:36 AM
Reneiria's Avatar
Reneiria
I must have been standing on my head yesterday..... the drivers side was BAS AACKWARDS!~ :mad ... All is fine now ... Thanks for the help :seeya
To Runs rough after plug wire change
