Replacing the coolant
#61
Pro Mechanic
~'95 or '96. Why?
#63
green or orange is no real huge difference in the LT1/4 cars... Hell you can run either in L98 cars too.
Early cars had green, later cars had orange...
DONT mix the two.
I suspect GM's switch to Dex-Cool in 95 or 96 had nothing to do with "Corvette" and everything to do with an entire change to EVERY car GM produced that year.
And I agree with Aklim: I change every fluid in used cars when I buy them.
DONT mix the two.
#65
GM started using dex cool in 96. I added new coolant and started up the car and let it ran for about 15 mins till the temperature gauge got to 185. I put the cap on and drove it around the block and the temperature slowly started to climb up past the middle.
I'm assuming I still have air in the system. What is the best way to get rid of the air. Should I let it run longer at idle with the cap off?
#66
Pro Mechanic
Open the bleeder screws with it not running. Air goes to the high points so check there, and open the cap on the surge tank...air should be there, too.
#67
I'm having a difficult time getting the air out. The temperature keeps on climbing, and once it get past half way, the expansion tank starts to over flow and I shut the car off. I know there still air in the the system. How do I get this air out?
I've opened the bleeder valve with the ign off for a few seconds till coolant comes out and i run the car with the cap off and still the temp slowly climbs up and the expansion tank will over flow.
This is a pita...why cant i get rid of this air in the system? Any other suggestion?
#68
#70
I don't know why so many people have such a hard time with this.
If you have to, let the thing cool down and then pull the tstat housing off, and fill the thing with coolant through the water pump housing. Fill it to the top so the tstat is sitting in coolant.
#71
Pro Mechanic
I don't either. Ya don't need to remove the t-stat housing. Fill it where it was meant to be filled, open bleeders 'till you get coolant, close and top the fill tank. DONE.
When are you getting over flow from the tank: running w/the cap OFF? If so, that's going to happen. Coolant expands as it heats, so it has no choice but to over flow the tank if the cap is off.
Fill the system cold to the top of the tank. Open the bleeder 'till coolant comes out. Close 'em. Top the tank again then put the cap on. Run the car. It should run and cool normally.
#72
#73
When I say impossible, I mean impossible to trap air under the tstat. I didn't read this entire thread but when someone complains about overheating after the cooling system has been drained then typically the problem is air under the tstat, which sort of prevents the tstat from contacting hot coolant (because the air displaces the coolant), so it wont open when it should, which makes the engine over heat.
#74
#75
Pro Mechanic
#76
the GM procedure, which BTW works, is to open the bleed screw at the thermostat housing and fill with coolant until you get a little coolant out of it. Then close it. Then top up the coolant to the bottom of the fill neck(it has 2 levels). Run the engine at idle for 4 minutes with the cap off and keep the level full. Install the cap. Fill the overflow to the cold line.
DONE.
It doesnt say to bring the engine to a certain temp, or rev the engine or anything of that nature.
You should use just shy of 4 gallons TOTAL. If you have a lot more than say 1 quart left, you didnt get it all in.
The system self purges air and will suck coolant back through the overflow line. Check the over flow after every drive for 3 or 4 heat cycles to make sure its not empty.
DONE.
#79
BTW this is the LONGEST coolant change in history...
Its been going on since July LOL....
