Fuel pump recomendation
Old Jul 9, 2018 | 03:00 PM
Rohn's Avatar
Rohn
Default Fuel pump recomendation
I have a 1984 corvette with stock fuel tank.
In car today is a new 396 forged small block (450HP?) with additional N20 at 100 hp. Port fuel. EFI. 43 lbs fuel pressure. After market ECU. I will be upgrading injectors to 40 lbs .
Currently injectors are 24 lbs..
Do you know of any MFG that can provide a FP that is a direct drop in?
Thank you.
Old Jul 9, 2018 | 05:40 PM
vader86's Avatar
vader86
Walbro 255 is what I use in my 398, from Racetronix. Do yourself a favor and get the upgraded in-tank harness and go ahead and replace all the factory stuff.
Old Jul 9, 2018 | 06:44 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
My .02 is to just drop in a AC Delco factory unit from 85-89. You will get an increase in pressure you need and you won't have to fiddle with different harnesses or worry about things not fitting.
An OEM swap will take no more than 45 minutes.
Old Jul 9, 2018 | 07:03 PM
C409's Avatar
C409
..... I got this Walbro 450-267 from FIC for about the same money as the 255 Walbro … Made in USA and E85 compatible … I'm currently running an Aeromotive 340 but its a China pump that may or may not like E85 … either way , you have fuel flow to grow into Horsepower-wise …..
Old Jul 10, 2018 | 01:05 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I really don't think that is going to cut it. You're suggesting an '85 - '89 stock pump is good for 550 hp? I don't think that it is.
Like some others have suggested, I'd go for something that is overkill so I'd have some head room. I ran a Walbro 255 for years and it was great, but that was for only ~300 hp. For your power, I'd go bigger.
Old Jul 13, 2018 | 12:05 PM
Rohn's Avatar
Rohn
Pressure is no issue. Flow is....My TPI pump holds pressure nicely at 43 lbs. It will fall short on flow(gal/liters pe hr). inlet and return needs to be upgraded. I will use 6AN (.375) inlet 4AN (.250)return..
Quote:" I got this Walbro 450-267 from FIC for about the same money as the 255 Walbro."
FIC did well by me on my port fuel conversion.
So will go that route
Old Jul 14, 2018 | 04:26 PM
C409's Avatar
C409
….. I'm using -8AN inlet and -6AN return ….. -4AN return may be too small …..
Old Jul 15, 2018 | 03:11 PM
rhandle's Avatar
rhandle
did you have to change out the whole fuel harness for this upgrade?
Old Jul 15, 2018 | 07:25 PM
C409's Avatar
C409
….. My fuel system was upgraded years ago ! When I changed out the dash to analog gauges , I made a bunch of changes to the cars wiring . This pump is still on the shelf and will be installed when the need arises OR when I find it necessary to go into the tank again ! Right now , The Aero 340 is doing just fine ! …..
Old Jul 15, 2018 | 08:39 PM
ddahlgren's Avatar
ddahlgren
Bosch 044 has always been a favorite for me.
To Fuel pump recomendation
