Emergency Break Handle Removal- Help
Old Jul 10, 2018 | 08:46 AM
Ruger72's Avatar
Ruger72
Default Emergency Break Handle Removal- Help
Hey Guys, I have an 89 and my emergency break handle has a lot of movement/play in the handle. I have purchased another E-Brake handle for it and want to put it in. I have pulled my seat out and have been searching for how to remove the handle. I know that there are the star bolts holding it in. But I can not figure out how to release/loosen the cable. Secondly, will I need to worry about any adjustment on the rear breaks when I swap the handle out? I am thinking I will not. I believe it is self adjusting. Any help/direction would be appreciated. Thank you in advance.
Old Jul 11, 2018 | 11:37 AM
BillDurant's Avatar
BillDurant
Default Handle try the YouTube Video below
Old Jul 11, 2018 | 04:49 PM
Ruger72's Avatar
Ruger72
Originally Posted by BillDurant
Great video. Thank you. Will I need to worry about any adjustment needed or if my rear breaks are going to change adjustment when I undo the cable and change out the E-Brake? I am thinking not. If my thinking is correct, I am just going to re-attach the cable to the new E-brake handle and it is spring loaded and will go right back to the same position and will not change anything else.
To Emergency Break Handle Removal- Help
