87 stalling when coming to a stop
Old Jul 10, 2018 | 01:39 PM
vtdave577's Avatar
vtdave577
Default 87 stalling when coming to a stop
My 87 Vette is having a problem with stalling when I come to a stop. As soon as I put the clutch in while coming to a stop, the idle seems to wander then slowly die. Any ideas?
Old Jul 10, 2018 | 03:12 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
First thing I'd do is check the fuel pressure. You could have a problem with the FPR, the filter, the pump or a combination. Attach the gauge to your windshild and go for a ride, watchign the needle. You shoudl have a consistent minimum of 40ish. If at the stop, your pressure drops, you need to trace your problem.
Old Jul 10, 2018 | 08:18 PM
Kevova's Avatar
Kevova
Clean throttle body bore and butterfly.
Old Jul 10, 2018 | 09:08 PM
WW7's Avatar
WW7
Clean idle air control , remove the plate it screws into ,then clean the air channels out..Put a drop of oil on the pintle to lube...WW
To 87 stalling when coming to a stop
