Throttle body play
Old Oct 21, 2002 | 08:03 PM
brookman's Avatar
brookman
Default Throttle body play
Are there replaceable bushings in the throttle body? mine has a lot of play on the cable side.
Old Oct 21, 2002 | 08:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Throttle body play (brookman)
You might be able to have a good machine shop put in bushings.
If you plan on some mods to your L98 you might just install a 52mm AS&M TB. Or perhaps AS&M can rebuld your stock unit; they aren't far from you.
[Modified by 65Z01, 6:31 PM 10/21/2002]
Old Oct 22, 2002 | 04:00 PM
Grouchy67's Avatar
Grouchy67
No, the OEM throttle body just has holes bored or cast in the casting. In process myself of trying to bore out o/s holes and using oilite bearings. Mine is an 89 but should be similar type set up.
Old Oct 22, 2002 | 06:50 PM
vetracer's Avatar
vetracer
I replaced mine with an exchange unit from TPIS. It fixed all kinds of driveability problems (high idle while coasting, RPM hunting on startup, sticking throttle). You can order one and send yours back to them for core credit once you receive the new one.
To Throttle body play
