throttle body up grade
Old Jul 17, 2018 | 08:03 PM
dennis m's Avatar
dennis m
Default throttle body up grade
1990 l98 engine has up grades cam heads exhaust has 48 cc throttle body thing of going to a 52 is it wroth the money
Old Jul 17, 2018 | 08:17 PM
383vett's Avatar
383vett
I would. Others may disagree. I used to run a 58mm on a 383 with good results.
Old Jul 17, 2018 | 08:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It would wise to also upgrade the runners.
Old Jul 17, 2018 | 08:45 PM
dennis m's Avatar
dennis m
does the minni ram really help that much cause you have to buy there fuel rail also and then bigger injectors?
Old Jul 17, 2018 | 08:59 PM
vader86's Avatar
vader86
You have zero need to upgrade your TB until you've upgraded the rest of the intake system. Once you've enlarged the plenum/runners/base, you may see some small gains from a TB change, but this is not a part that gives you a bunch of HP even then.
If you change to MR, you will need to do a lot of things as well to get the combination correct. Dont know if your current injectors to feed the cam you have are enough with this added airflow, and finally a chip tune. Do not just blindly swap a MR on there without thinking out what you want from the car.
Old Jul 18, 2018 | 11:01 PM
89dd's Avatar
89dd
I upgraded to the Holley 52mm only because the shaft on my original was sticking and another forum member was selling one.
Noticed a little better throttle response but overall the same performance.
Mine is a stock 89'
Old Jul 19, 2018 | 08:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
on a 350 tpi waste of money.
Old Jul 19, 2018 | 06:59 PM
aklim's Avatar
aklim
IIRC, unless you are going north of 500, it is not worth the upgrade.
Old Jul 20, 2018 | 12:55 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
:agree:
Sure...but you've got a 600 hp motor, or so.
Only reason why you'd put a TB on a stock or stockfish TPI would be to have more throttle reaction/response. Is it worth it? Probably not. For the price of a TB you could buy a cam which would increase power 10X more than a TB will.
Old Jul 20, 2018 | 02:57 PM
856SPEED's Avatar
856SPEED
I agree. 48 mm is what GM has on the LT4 cars in 96. I think they flow nearly 660-700 CFM.
More than enough for a 350 TPI car at 230-250 hp. Even if you are making that at the wheels with your upgrades, that’s plenty of throttle body.
To throttle body up grade
