as & m runners
Old Oct 22, 2002 | 11:21 AM
DADDY D's Avatar
DADDY D
Default as & m runners
where do you find a set of these runners that i hear about anybody know what they flow as well
Old Oct 22, 2002 | 12:15 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: as & m runners (DADDY D)
here is their website.
http://www.azspeed.com/
Sorry I don't know what they flow
Old Oct 22, 2002 | 05:03 PM
BLUE ONE's Avatar
BLUE ONE
You've got the link to there web site, they flow 199 cfm through a stock base ( std runners flow181cfm ) and 206 through a ported base ( stk flow 196 ) and 211 cfm through a larger aftermarket base. :D
:cheers:
They are the best runners from a flow and performance point of view for LTR'S :yesnod:
Old Oct 22, 2002 | 06:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I was in Chandler, AZ early this year, I bought a set of AS&M LTRs; later I sold them to Vic'89 since I developed another plan for my intake.
Anyway, you can see from his sig what they and an Accel base did for his performance, and that's with stock heads, cam and no headers.
These LTRs and the AS&M TB are realy nice pieces, with very good quality.
Old Oct 22, 2002 | 06:26 PM
ZylaRace's Avatar
ZylaRace
Default Re: as & m runners (65Z01)
P# 20199-T5 $400
They are difficult to do business with.
They also think there stuff is worth it's weight in gold.
On the bright side, it does deliver.
Old Oct 22, 2002 | 07:27 PM
1991Z07's Avatar
1991Z07
Default Re: as & m runners (BLUE ONE)
We flowed them while we were putting the motor together....218 CFM they flow all on their own. [Edit] Of course now they show that the LTR's flow 260 CFM on the AS&M site...not so sure if I believe that unless they changed the size of the tubes.
We keyed the rest of the intake flows off the runners.
[Modified by Joe90, 8:23 AM 10/23/2002]
Old Oct 23, 2002 | 01:26 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: as & m runners (Joe90)
Maybe that 260cfm figure is for their siamesed runners :confused:
and they got it wrong on the site typo wise... duno
I agree with you 218 sounds about right for the runners on there own.
:cheers:
Old Oct 23, 2002 | 04:03 PM
DADDY D's Avatar
DADDY D
so these runners are better than the siamsed runners
Old Oct 23, 2002 | 04:19 PM
BLUE ONE's Avatar
BLUE ONE
They are the best LTR'S.
When you say, so they are better than siameses runners, i think that would depend on the apllication and egine spec. I have heard that they perform better than some siamesed runners ( no loss of low speed torque ) but i have not run them myself, so cannot offer a tested opinion. If you are running an auto i would go with the asm's
I'm running 12.8's on asm's others have gone 12.2 so i will not ever change mine as i think you only gain 2-300 rpm.
I would go super ram if i ever upgrade my intake :)
Hope that helps
:cheers:
Old Oct 23, 2002 | 06:23 PM
1991Z07's Avatar
1991Z07
I agree with Blue One on this... depends on the application.
You CAN get 400 FWHP from the LTR's, and if you want the upper RPM breathing can siamese the base to get there. It gives you the stealth of "...just another TPI" and quite honestly I like the looks of them.
Mine are now powder-coated with black wrinkle-coat along with the valve-covers and entire intake. I should have the motor back next week and can start installing it again. I'll dyno it again and post what the siamesed base added to the package, as that is the only change we did (long story...spun 2 rod bearings).
I saw some comparisons before we built this the first time, and they flowed all of the aftermarket runners. The AS&M LTR's came out on top as far as flow was concerned...even over the siamesed runners. It is one of the contributing factors into why I picked them over anything else.
To as & m runners
