Performance upgrade 1986 corvette - your take
car - 1986 l98 TPI engine
injectors - 24Lb
Engine type - Must stay TPI with original style intake
Idle - smooth at 600-700 RPM
looking to upgrade torque and HP (priority to low end torque)
400 ft/lb min.
what configuration will do the best with zz4 short block new Chevrolet Performance 12670966
intake original or SD3816 TPI Base
what heads would you pair with the base
GM Cast Iron vortec 19331470
GM aluminum fast burn 19300955
AFR - 180cc or 195cc Eliminator aluminum
AFR - 190 Eliminator vortec aluminum
Cam - please recommend
will probably need a new chip
