oil pressure sensor 92 c4
Old Oct 22, 2002 | 03:37 PM
Frank92's Avatar
Frank92
Default oil pressure sensor 92 c4
i still donīt know where the sensor is located. maybe some one could help with digi cam ?
thanks frank
Old Oct 22, 2002 | 03:39 PM
scorp508's Avatar
scorp508
I think it is in the same place as an L98. It would be on the very top/back of the engine block on the driver's side. It is to the left (if looking from driver's seat) of the distributor on an L98. Has a single wire connector on it.
Old Oct 27, 2002 | 11:19 AM
Frank92's Avatar
Frank92
Default still searching
there is a round "thing" with a vacuum line in that place , and a small metal tube with three wire elect. connector.
frank
[Modified by Frank92, 3:21 PM 11/1/2002]
Old Nov 1, 2002 | 05:24 PM
Frank92's Avatar
Frank92
Default Re: still searching (Frank92)
to the top
Old Nov 1, 2002 | 07:56 PM
ittlfly's Avatar
ittlfly
frank
The "round thing with a vacuum line" is the EGR valve. the sensor you are looking for is just to the right of it (looking from the front bumper) ....and tucked down against the firewall.
To oil pressure sensor 92 c4
