driver side front damper hot to touch normal?
Old Jul 28, 2018 | 10:18 AM
barchetta1's Avatar
barchetta1
Default driver side front damper hot to touch normal?
Ive been trying to evaluate if my original Bilstein dampers on my 96 are still operating correctly. Today after a 40 minute drive I felt the the lower half of the dampers in the front and notice they were unbalanced. The drivers side was hot to the touch, I would guess 180f and pass was just warm.
Can someone confirm if this is normal on a vette?
I figure if its not either the drivers wheel is unbalanced or the passenger shock is bad. I may have figured wrong but any input would be helpful.
thank you
Old Jul 28, 2018 | 10:24 AM
PatternDayTrader's Avatar
PatternDayTrader
Im thinking the passenger side is messed up.
Old Jul 28, 2018 | 10:50 AM
WVZR-1's Avatar
WVZR-1
Get an IR device so that you can be 'maybe' more factual with what you find. Don't know that you could compare fronts to rears on the same car but if posted IR readings others that have IR devices (I'm guessing many) could post back after checking theirs.
Old Jul 28, 2018 | 11:08 AM
barchetta1's Avatar
barchetta1
I dont need an temp gauge, the difference is extremely noticeable. In fact I have one but there is no need to use it. If I told you the right side was 190 and left was 120 what would you say? 215f will cause human pain which is why I know it is below 215f.
I just need someone to look at theirs. The lower a arm is also noticeably warmer. Could be from the shock or from the ac/alternator. Those two units are all I can see as a difference side to side.. but perhaps there is a path where theexhaust manifold creates heat on that side. this is why Im asking someone to have a look.
I will check rears though but Im not sure if it is relative.
I would tend to agree that it is very possible my passenger side is outside normal operating parameters or, f'd up.
Edit: I hate, despise spending my hard earned cash unnecessarily. Especially on a toy.
EDIT: on the LT1 there are many more accessories on the drivers side. master brake, asr, ac, alternator. Airtflow could and is likely much less accross the exhaust manifold on the drivers side.
Old Jul 28, 2018 | 11:18 AM
barchetta1's Avatar
barchetta1
Im tending to agree.
Old Jul 28, 2018 | 11:29 AM
PatternDayTrader
Dampening causes friction and heat. No heat makes me think there's no dampening.
Old Jul 28, 2018 | 11:37 AM
383vett's Avatar
383vett
Why would he need an IR device? He can hold one shock (yes shock) with his whole hand and not get burnt. The other side leaves blisters after 3 seconds. That seems like a conclusive, scientific measurement to me.
Old Jul 28, 2018 | 11:40 AM
WVZR-1's Avatar
WVZR-1
So the OP just goes for a 'cruise' and 'palms shocks' - that should work!!
https://blog.ryderfleetproducts.com/...ber-heat-test/
Old Jul 28, 2018 | 11:50 AM
383vett's Avatar
383vett
No stupid, damper.
Old Jul 28, 2018 | 12:42 PM
rjacobs's Avatar
rjacobs
pull shocks...
Move them in and out by hand.
If a shock is completely wrecked it will have no resistance in either direction. Bilsteins TYPICALLY have a lot of damping and are very hard to manipulate by hand.
BUT if a shock is that bad, IMO you will notice it when driving.
Have somebody drive next to you on a not so smooth road and watch each wheel. Its very easy to tell if a shock isnt working because the suspension will be all over the place.
To driver side front damper hot to touch normal?
