Indexing Spark Plugs
Old Jul 28, 2018 | 10:22 PM
C409's Avatar
C409
Default Indexing Spark Plugs
….. What say you ? … Any power to be had ? … Did I waste my time ? ….. It was relatively easy to do on the stand vs in the car …..
Old Jul 28, 2018 | 11:00 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Nah, you did nothing to hurt your effort, but I Really don't know if there is any measurable gain.
I remember when I was a teen I read an article in CAR CRAFT magazine about indexing my plugs. I did a set for my 71 roadrunner. I thought I was "on to" a speed secret my friend didn't have. The big Block Nova's still beat me.
Old Jul 28, 2018 | 11:38 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I've done it before. Did it help anything? Heck if I know. But if its easy to in the stand than why not? Took me hours to do from under the car and over the fenders. I just bought a full extra set of plugs, marked the insulator side with the ground electrode using a permanate marker and found a plug that would seat where it should instead of using the little ring spacers they sell.
Good luck.
Ooops I see your already there with the marker and extra plugs. Congrats.
Old Jul 29, 2018 | 01:09 AM
ddahlgren's Avatar
ddahlgren
Don't use black marker it has carbon in it.
Old Jul 29, 2018 | 06:28 AM
hcbph's Avatar
hcbph
I suspect that unless you are using domed pistons or have something shrouding the spark plugs you'll likely not see much if any advantage to index plugs in your engine.
It won't hurt but I don't think you're going to see any improvement.
Old Jul 29, 2018 | 08:03 AM
Joe C's Avatar
Joe C
you'll probably see better SOTP performance with this...
Old Jul 29, 2018 | 08:28 AM
C409's Avatar
C409
….. I thought about whether or not I had just inadvertently deposited an electrical path on the ceramics … so I washed the marker stripes off when I finished getting the plugs indexed …..
Old Jul 29, 2018 | 08:41 AM
C409's Avatar
C409
….. Meh ! … the only way for a Mopar to beat a Big Block Chevy was to index the plugs AND hang a supercharger on it ! … …..
Old Jul 29, 2018 | 09:31 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Can't hurt and better balances out each cylinder as they are firing the same. Will it be a huge amount, no, but as you yourself know, each incremental improvement adds to the whole.
Here are some takes on it:
https://www.enginelabs.com/news/gett...-indexing-101/
http://www.eatonbalancing.com/2009/0...plug-indexing/
The one from Eaton Balancing evens shows how to make a little tool for future aligning. In the Eaton one, the author even discusses how detonation can be effected by electrode alignment and how the electrode can split the flame front. It was kind of interesting.
Thanks for bringing this up. I had to go out and do some searching and reading. That is how I found the above links.
Old Jul 29, 2018 | 09:49 AM
NavAir's Avatar
NavAir
I'm a skeptic. The effect would be theoretical, and so small as to be unmeasurable. The way to test would be to install all plugs in the most 'disadvantageous' position (ground electrode toward the intake) and dyno the engine, then index all of them and retest. You can't reliably measure less than a 10 HP difference on sequential dyno runs, and I would anticipate that if there is a difference with indexing, it would be on the order of 1-2 HP at most.
But, hey, if your hobby is working on engines...
Steve
To Indexing Spark Plugs
