C-Beam Question ??
Old Aug 1, 2018 | 10:54 PM
Krusty84's Avatar
Krusty84
Default C-Beam Question ??
I have tried searching and can't find an answer to my question.
Will a C-Beam from an automatic (D36) bolt to a D44 rear end?
I need a C-Beam that is going to get shortened/modified to accommodate my LQ9/TKO600 setup.
I know the C-Beams are different lengths but that isn't my concern as it will get chopped. I just need to know if a cheaper D36 C-Beam will bolt up to my D44.
Thanks,
Krusty
Old Aug 1, 2018 | 10:58 PM
WVZR-1's Avatar
WVZR-1
Thanks,
Krusty
The C-beam at the pinion is the same. If you're going to 'whack' one, anyone that you have should do. You might make sure the bores are round and not 'egg-shaped' from wear. The D36 is longer.
Old Aug 1, 2018 | 11:18 PM
Krusty84's Avatar
Krusty84
Awesome. Thanks.
Now I just need to find one for a good price.
Old Aug 2, 2018 | 08:39 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Read your PM's
To C-Beam Question ??
