Borla or Corsa mufflers?
Old Aug 8, 2018 | 02:21 AM
Isaiah_moski's Avatar
Isaiah_moski
Originally Posted by aklim
Depends. Do you need the noise to introduce yourself and if so, how much are you willing to spend on that pleasure? Unfortunately, my combination of LT headers, higher flow cat and Borla cat back is too noisy for the wife and myself so if I had to do it again, I'd go Corsa in hope of a quieter system.
Yeah I definetily want it to be nice and noticeable but not super loud. Sounds like Borla might be too much for me
Old Aug 8, 2018 | 08:39 AM
aklim's Avatar
aklim
I had to put a high flow cat to get it down some. If I had to do it, I'd go with whatever was quietest with the least flow restriction.
Old Aug 8, 2018 | 01:08 PM
ChumpVette's Avatar
ChumpVette
Headers completely change the tone of any catback system. Including Corsa. The Corsa will still be manageable from the inside, but it definitely doesn't have the same characteristics with factory manifolds and cats.
Old Aug 8, 2018 | 01:55 PM
aklim's Avatar
aklim
Definitely but from what I am reading, Corsa seems to be able to flow as much WITHOUT as much noise which is what I would want. Unfortunately, I have too much invested in the Borla and don't really want to spend more money unless some killer deal comes along where someone has a used set and I can sell my Borla.
Old Aug 8, 2018 | 02:01 PM
SG Lou's Avatar
SG Lou
Corsa, Sounds great and no drone.
Old Aug 8, 2018 | 02:09 PM
aklim's Avatar
aklim
I wonder if they have done any tests with a sound meter INSIDE the car and see how much the sound level is with each different system. Obviously a Mustang will be different from a Camaro or a Charger or vette but that is a guide to the engineering.
Old Aug 8, 2018 | 06:27 PM
Isaiah_moski
Originally Posted by RetroGuy
I do believe the "mid back part" you're calling a cat, is actually a resonator. Am I wrong here, or do California C4s have 3 cats (one on each side forward, and one the two pipes flow into together at mid section)?
It may be a resonator I’m not sure.
Old Aug 8, 2018 | 07:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
OP.
If it's '84-'91, it's a catalytic converter.
If it's '92-'96, it's a "resonator"....i.e. another muffler.
Old Aug 8, 2018 | 08:05 PM
aklim's Avatar
aklim
Originally Posted by Tom400CFI
OP.
Why does it have 3 cats for early and late 2? Did something change with the LT1 emissions wise?
Old Aug 8, 2018 | 09:45 PM
ChumpVette's Avatar
ChumpVette
Just like everything else, technology gets better. Didn’t need three cats in the LT1.
Old Aug 8, 2018 | 10:23 PM
aklim's Avatar
aklim
I did not think that the LT1 was that much improved over the L98. You may have a point
Old Aug 8, 2018 | 11:17 PM
ChumpVette's Avatar
ChumpVette
Catalytic converters technology may have improved. Emissions production and types of emissions may have gone down with the LT1. Or the design of two large size cats instead of two small size and one medium sized cat won over.
Old Aug 8, 2018 | 11:29 PM
  #33
aklim's Avatar
aklim
All possible. I bought the 91 to transplant my newly built and tuned L98 from the F-body that got wrecked so I didn't really drive it much or bother to look under the hood too thoroughly to notice anything other than where the plug for this, that or the other went to and from.
Old Aug 9, 2018 | 09:02 AM
  #34
9T3VETTE's Avatar
9T3VETTE
https://youtu.be/Dimat2IfnFk
Sounds great! Do you have any drone with that setup? It's time for me to dump my MF system and i'm debating between stock mufflers or Corsa. The problem I have is paying 1k for a Corsa system and only using from the diff back. Used ones seem non-existent....
Old Aug 9, 2018 | 09:08 AM
  #35
TorchTarga94's Avatar
TorchTarga94
For what you are wanting go with Corsa. Buy once/Cry once.
I've done them all on my 94' and finally ended up with Corsa. Sounds great. The only other combo I would consider on a stock L98/LT1 would be long tubes into stock LT1 mufflers (also sounds awesome with a small performance boost).
Old Aug 9, 2018 | 01:05 PM
  #36
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
purchased a borla cat back a long time ago for my 89 coupe...and let the drone begin. switched to corsa and never looked back. nice sound at idle and low speed but look out at wot.
Old Aug 10, 2018 | 12:09 PM
  #37
design god's Avatar
design god
Originally Posted by isaiah_moski
hey all, i have an 86 l98 completely stock at the moment. Planning on getting some exhaust work done. I'm between borla or corsa. So far my understanding is that borla sounds better but corsa has less drone. I want the best possible performance and minimal drone. At the same time i want people heads to turn haha. I want it to sound good but not be overly loud. Good for the street, not for the track if you know what i mean. Thanks in advance for any advice!
go with the borla. I had one. Much better than corsa
