1985 Corvette New Clutch Grabs High
It was grabing say at abit more than half of the clutch out with the old one but since I put the new one in, it was grabbing at about the same place but it keeps on getting higher and higher overtime. I did 1000 miles with the new one now. Not really any signs of it slipping tho like I did a clutch drop to see the other day and she did a beautiful burnout.
I don't do racing or anything with it so I'm not hard or anything on it. Replaced the master 2 weeks ago cause it was leaking inside the car and the pedal is smoother but hasn't come up. Also I bleed it really well with a method I knew before and there is no air in there. The fluid was very very dirty but I cleaned the line and slave at the bottom with brake clean and air but it could be the slave the problem but I don't know.
If anyone else is experiencing this problem please let me know how you guys solved it cause it's really hard to find some info on this and I'm wondering if they all grab really high like that or is mine having an issue...Thanks!
