Fuel pressure adjustment?
Old Aug 8, 2018 | 03:22 PM
mlm0's Avatar
mlm0
Default Fuel pressure adjustment?
I’m installing adjustable FPR in my 89. Is the 43.5 psi without vacuum hose connected?
Old Aug 8, 2018 | 05:29 PM
silvvette's Avatar
silvvette
correct, remove the vacuum line and cap it so there is no leak. With engine off and fuel pump running, pressure should be 43.5
what afpr do you have?
Old Aug 8, 2018 | 05:41 PM
mlm0's Avatar
mlm0
I bought it of this forum. I will check when when u get home
Old Aug 13, 2018 | 11:56 AM
mlm0's Avatar
mlm0
What I bought is just a new adjustable housing that bolts onto the old regulator housing, but is adjustable. It also came with a round disk that lays on top of the old diaphragm and the new adjustment screw puts pressure on the diaphragm to lower or raise it. There is no markings on it
To Fuel pressure adjustment?
