85 throttle body linkage leak
Old Aug 8, 2018 | 07:16 PM
xrav22's Avatar
xrav22
Default 85 throttle body linkage leak
I have been chasing an air leak since doing my manifold gaskets. I was cleaning the throttle body when I blew can air into the small hole inside by the butterfly. I noticed
air bubbles coming out of the linkage between tps sensor and body where the linkage rotated. Just to confirm that is not normal and I have worn my throttle body out.
Thanks for tips
Old Aug 8, 2018 | 07:43 PM
badduxx's Avatar
badduxx
According to the Haynes manual, the throttle body is not serviceable and must be replaced.
Old Aug 8, 2018 | 11:10 PM
aklim's Avatar
aklim
Haven't had that so I'm going to go with getting a new one. Some have rebuilt it but not sure how good it is or worth it.
Old Aug 8, 2018 | 11:27 PM
xrav22's Avatar
xrav22
Well after todays recheck on all things above the intake, I noticed the bubbles because I sprayed cleaner all over. Then drying with can air I noticed bubbles.. Before intake gasket replace it seemed ok but I had several loose screws so it must have been leaking in a few spots. I will try smoke test now that I am making progress. Car is ok but I am trying to perfect the idle.
Thx
To 85 throttle body linkage leak
