c4 lt1 dies after a while
Old Aug 12, 2018 | 09:22 PM
amr na's Avatar
amr na
Navigator
Default c4 lt1 dies after a while
here is the story i changed the opti last week started the car run for about 2 miles then the car dies when im parking
tried to starting it up again it idleing for about 30sec then dies tried this a couple of times now it wont start crank but wont start
any ideas what could be wrong and where to start
thnaks
Old Aug 13, 2018 | 10:06 PM
larry_c4's Avatar
larry_c4
Bang on the ECM while the car is running and see if it dies or sputters. It is common for ‘90-‘93 corvettes to develope a loose solder joint which makes the car do things like that. Also, have you pulled codes via the digital dash?
