‘92 LT1 Coolant bleeding question
Old Aug 13, 2018 | 09:55 PM
larry_c4's Avatar
larry_c4
Default ‘92 LT1 Coolant bleeding question
I blew a hole in the top rear radiator hose today. Since I am going to be replacing the hose, I will have to add coolant to the system. I did not loose a lot of coolant, and I
had a recent flush. My question is, when filling the system, which bleed screw do I open? I see there is one on top of the thermostat housing and there seems to be one under the throttle body. I am also confused because there is a port on the bottom of the throttle body by this bleed screw that is capped off, I included a picture to illustrate. Any help is appreciated.
Old Aug 14, 2018 | 06:10 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
The cap is a sign that someone has done the throttle body bypass. That means there is no coolant in that unit. You therefore only have to use the bleed valve at the T-sat housing.
Old Aug 14, 2018 | 09:57 PM
larry_c4's Avatar
larry_c4
Ok so I will not have to use the bleeder screw on the throttle body. Interesting that someone must have disconnected the throttle body line. I never noticed freezing in the TB in the winter. Makes sense that it was disconnected though to allow for colder air in the TB.
To ‘92 LT1 Coolant bleeding question
