When do i need new fuel pump and injectors?
Old Oct 23, 2002 | 01:21 PM
devilfish's Avatar
devilfish
Default When do i need new fuel pump and injectors?
At what hp must i change these parts to better ones?
Will the stock ones be enough with 400hp at the crank?
Old Oct 23, 2002 | 05:04 PM
devilfish's Avatar
devilfish
Default Re: When do i need new fuel pump and injectors? (devilfish)
tt
Old Oct 23, 2002 | 05:56 PM
gtsyellow's Avatar
gtsyellow
TPIS told me my engine was boarderline on the stock fuel pump so i bought one of there high output bosch pumps. i'm making around 425hp at the flywheel. normally people change out the pump at the 400hp. another reason i did is becuase my car is a 1990 & that's a lot of years on the pump & also the injectors. i have an extra set of bosch pintile injectors that have all been flow balanced i'd be willing to part with for $220USD, TPIS sold the injectors to a friend of mine who later upgraded to a larger size {they were $495.00 from tpis}. these are 24lb/hr & have less than one oil change on them. just ask if you'd like to see any pics.
Old Oct 23, 2002 | 06:01 PM
devilfish's Avatar
devilfish
Default Re: When do i need new fuel pump and injectors? (gtsyellow)
yes please, pics would be nice.
So if im around 400hp at the crank, the stock inj and pump would be fine?
Is it good to flow test the inj to se if they is good? And what should they flow?
Regards
Old Oct 23, 2002 | 06:37 PM
vader86's Avatar
vader86
the stock system should be able to hold up to that HP, as should the injectors
Old Oct 23, 2002 | 06:46 PM
gtsyellow's Avatar
gtsyellow
Default Re: When do i need new fuel pump and injectors? (vader86)
the stock pump can probably hold but again it's aged. the injectors i do think should be changed, i mean they are 12yrs old, that's a lot of gas firing through them. i'll take a pic of them & post back within 6hrs
Old Oct 23, 2002 | 06:48 PM
devilfish's Avatar
devilfish
nice...
Old Oct 23, 2002 | 06:57 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
It should support it, however if you run a power adder such as Nitrous, it is an excellent idea to get an upgraded pump at the very least. Not sure if you are or not so I thought I would throw it out there.
Old Oct 23, 2002 | 07:31 PM
J Z06's Avatar
J Z06
When my car came back from LPE In 1997, it had larger 26# injectors...but everything else was stock(Save for an adj regulator). I upgraded to a vortec truck pump though, and it's been working fine. My Car makes 440 hp at the crank.
Old Oct 23, 2002 | 09:01 PM
gtsyellow's Avatar
gtsyellow
here you are
Old Oct 23, 2002 | 09:05 PM
Nathan Plemons's Avatar
Nathan Plemons
What size are stock L98 injectors?
The LT1 has 24's from the factory and can easily support 400 at the flywheel. I'm pushing 365 at the wheels using my stock fuel pump. I've got some SVO 24# injectors that I got at a good price. I'm not sure that I need them, but they certainly won't hurt anything.
I'm thinking about upgrading to a set of SVO 30's that I can again get at a good price.
Old Oct 23, 2002 | 09:31 PM
gtsyellow's Avatar
gtsyellow
Default Re: When do i need new fuel pump and injectors? (Nathan Plemons)
stock for the 90-91 is the rochester 22lb/hr ball injector, they probably would be alright at 350-375hp if they were working perfectly, it's just fish has 12yr old injectors. i know mine were about kuput when i pulled them out before i bought the new 24's. going to a 24lb like the lt1s had also will carry a person to 450hp pretty well.
Old Oct 24, 2002 | 12:30 PM
devilfish's Avatar
devilfish
Im thinking of getting VOLVO 850 R injectors. They are a direct fit, and flow 36 lb/h:) I can get 8 of those for $300 here in Sweden. WHat fuel pump should I get. I whant to be on the safe side..
And thanks for the pics !
:seeya
Old Oct 24, 2002 | 12:58 PM
Raistlin's Avatar
Raistlin
36 lb/h would be way over kill. you'd have to turn the pressure way down to keep it from running really rich and then you'd get a crappy spray pattern. (assuming you're still at 350 cu in and not super charged)
:cheers:
Old Oct 24, 2002 | 01:32 PM
devilfish's Avatar
devilfish
Default Re: When do i need new fuel pump and injectors? (Raistlin)
ok 36 is to much.. hmm...
I will se what stock 850 none R injectors will flow.
Regards
Old Oct 24, 2002 | 05:25 PM
gtsyellow's Avatar
gtsyellow
i wouldn't think UPS would be very expensive to ship there, maybe $30-40usd, does your country have heavy import fees? i don't mind working with you somewhat, i just have two sets of these & wouldn't mind selling the second
Old Oct 25, 2002 | 02:12 AM
gtsyellow's Avatar
gtsyellow
injectors sold to other forum member as the intrest in sweden seemed to be lacking, guess this post worked as a parts forsale ad :lol:
To When do i need new fuel pump and injectors?
