1992 Corvette Code 16
Old Aug 15, 2018 | 05:00 PM
sydneyACE's Avatar
sydneyACE
Default 1992 Corvette Code 16
I have a customer's car in here at the shop.
1992 Corvette...
Had a crank, no-start when hot. I changed the Optispark on it (aftermarket from O'Reilly's), as well as the water pump, plugs, and wires.
That fixed him up for about 4 months, then it came back in again with a check engine light... Code 16...
So I replaced the Optispark again, under warranty for him.
That fixed the code 16, but it picked up a misfire...
I spent a bunch of time trying to figure out what I did wrong during the install... couldn't find anything wrong, so I decided to warranty the Optispark again.
That fixed the misfire, and he was good for another couple months....
Well, now the car is back again... another Code 16.
Can't see any evidence of water intrusion or anything like that. (I explained to him about being very careful when washing the car, etc.)
Am I just getting junk Optisparks?
Is there some other component that could be frying these Optis? (Bad coil, etc?)
Is there another component that will throw a code 16?
We're on our 3rd Opti here within a year... makes me feel like I'm missing something, but every time I replace the Opti, it fixes the problem...
Old Aug 15, 2018 | 05:14 PM
Kevova's Avatar
Kevova
It might be worth changing brands. I would talk to part supplier about it. If he is your primary parts supplier, he maybe willing to work with you.
Old Aug 16, 2018 | 08:46 AM
fake's Avatar
fake
Do you have the original opti if so send to opti doctor. The opti at Oreilys is not like a delco . Checked one out and walked out of store.
Old Aug 17, 2018 | 12:51 PM
sydneyACE's Avatar
sydneyACE
Original Opti went as a core to O'Reilly's.
Old Aug 17, 2018 | 12:53 PM
sydneyACE's Avatar
sydneyACE
Customer said he is willing to go with a Delco Opti... I just want to be sure that I'm not missing anything here.
Has anyone seen a Code 16 that was caused by something other than a bad Opti?
Old Aug 22, 2018 | 10:12 AM
sydneyACE's Avatar
sydneyACE
Anyone?
Old Aug 22, 2018 | 10:31 AM
Kevova's Avatar
Kevova
The jumper harness from opti. The code 16 chart is very simple. Are you diagnosing using chart or dtc 16 means opti is bad? Since every time it quits you replace opti, it seems it's either opti, jumper, or wiring or connector to jumper.
Old Aug 23, 2018 | 05:50 PM
pearlmom's Avatar
pearlmom
I have an opti from O'reillys also and the first one had a rotor screw just laying in there. Put Locktite on it and lasted two years. Just changed it out 2 months ago under warranty, good so far. Had a Petris opti before that and always had a top end stumble, was the opti all that time but warranty was out.
Old Aug 24, 2018 | 10:56 PM
skinnyt's Avatar
skinnyt
1992 Corvette...
buy oem parts only is what I say
rockauto
Old Mar 30, 2023 | 12:43 PM
johnnyw's Avatar
johnnyw
Thank you to everyone !!!! It could be that we are getting somewhere !
To 1992 Corvette Code 16
