Finally, less drone!
I posted this also on another long thread, but felt too excited to leave it hidden there:
My California model 1996 LT1's former loud droning exhaust set-up was as follows: Stock exhaust manifolds leading into two stock cats (one on each side) then into the single stock resonator, then leading into a pair of Magnaflows that had a slightly larger pipe leading into each of them. This set-up caused a loud cabin drone when accelerating, especially on an incline...OMG. Sounded great on the exterior, but irritating on the interior.
I just had a Magnaflow #12468 (a kind of resonator/muffler with an internal X-pipe design) installed replacing my stock resonator. Same basic size as the stock one with dual 2.5" inlet/outlets. It won't easily bolt on without a lot of fabricating of pipes/fittings, so use a pro muffler shop, unless you're a welder. I had a pro muffler shop weld the new resonator into place. Now The Big Discovery: This new Magnaflow resonator has the x-pipe design, BUT the old stock resonator had a straight through design of two separate perforated pipes traveling through the housing and never completely mixing or crossing the exhaust flow. The x-pipe mixing design of the Magnaflow resonator lowered the original loud drone of my rear Magnaflow mufflers. I was able to obtain a noticeable decrease in drone! I'd estimate it decreased by 20% to 30% even on the dreaded accelerating inclines. I have no sound reducing material plastered all over the floor or rear cargo area either. I guess I could always do that if I wanted to spend another $200+, but I'm happy with the reduced noise as is. My muffler set-up has produced no codes or warning lights either. I'm hoping I created a tiny bit more performance exhaust flow with the internal x-pipe design of the new Magnaflow resonator. Therefore, for anyone out there with a stock '96 LT1 exhaust system or similar that wants a more aggressive exhaust note with just a little livable drone...this Magnaflow set-up could be it. I was told my rear Magnaflows (polished stainless steel) cost the previous owner approx $400 for the pair. The Magnaflow resonator cost me $105 on Ebay. Even with pro installation charges, this is still waaay cheaper than a Corsa system, however with just a bit of livable drone. Rather large photos below...
TTT, Too significant to be buried...
might give this a go on an l98. thank you.
I removed my gutted cat installing an inexpensive Amazon stainless steel glasspack in its place. I didn't have a droning problem - Allen's chambered eliminators in place of the mufflers - but this really improved the tone and actually the part-throttle response of the car. Same idea, just a little different arrangement on the '84.
So to reiterate, my original post about achieving reduced exhaust drone noise in my '96 LT1, that originally had the stock resonator & Magnaflow mufflers, was that the "trick" lies in replacing your old stock resonator with a Magnaflow #12468 (or another similar brand with internal x-pipe design). Once again, the stock resonator has a straight-through design of two separate perforated pipes traveling through the resonator housing and never crossing. So glad it worked, cause I was prepared to buy the "factory looking exhaust" that's designed as close to the original GM muffler as possible, from the Corvette Forum Store. The new resonator reduced drone and saved me some $$$. I was also able to keep the look of my rear mounted Magnaflow mufflers.
When I first took off my mufflers, the drone was horrible in the cabin. After I took off the stock resonator and added a x-pipe, all of the drone in the cabin was gone. This is what it sounds like. There's not too much you can do in a California car.
Your idling and revving sounds good, BUT the real test is accelerating steadily up a grade such as an on ramp. Hope your Vette's drone improved there too.
Idk why anyone doesn't talk about the OBX EXHAUST!?....I just installed this system (center resonator back) on my 87 and it is incredible!...quieted the car down considerably! As far as drone,...I don't have any that is bothersome. Sounds like a better now!.....
I had only muffler delets, and my car sounded like an ol Chevy longbed truck with a hole in the muffler!...lol
TPIS LT Headers, Magnaflow cat and Corsa cat back. Now I can think and hear myself think in the car. The Borla cat back was droning in the city and loud and noisy past 3000. Wife hated being in it, much less driving it. Now she is ok with both.
https://www.youtube.com/watch?v=j8wtUVL1VvM
Thanks,
Ronn
