Heater Blows Cold & Climate Control Blinks
Old Oct 23, 2002 | 04:33 PM
tdock's Avatar
tdock
Default Heater Blows Cold & Climate Control Blinks
When the engine is up to temperature, the heater still blows cold air. Also, I've noticed the climate control auto light blinks for a minute, which according to the manual could mean an electronic problem. All the other climate controls seem to work ok, like the blower & vents. Is there a key sequence to pull codes from the climate control programmer?
Old Oct 23, 2002 | 04:51 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Heater Blows Cold & Climate Control Blinks (tdock)
This thread shold help:
http://forums.corvetteforum.com/zerothread?id=394338
Old Oct 24, 2002 | 10:11 AM
tdock's Avatar
tdock
Default Re: Heater Blows Cold & Climate Control Blinks (Steel Blue 91)
Did the DTC thing in the link above, got a 01 "temperature door motor circuit fault. What I have gathered from previous threads, I need to remove passenger side front wheel, wheel well to get to the temp door motor? Does this sound about right. Or is it right behind the blower motor?
To Heater Blows Cold & Climate Control Blinks
