Getting ready for autocross
First off, please understand my car (1985 4+3) is in decent shape, but it's thirty years old without any major work (just fluid changes). I understand this puts wear on the car but I don't want to blow up the engine.
That said, is this a terrible idea? Am I going to destroy my car? At the end of the day I don't have the money or time to be constantly replacing major components.
If it's something you think I shouldn't have issues with, what should I do for my car before going. I'm not talking major mods, more "change brake pads", "make sure X is in good condition", "get a racing clutch", etc.
I do not expect to win any events, that's not why I'd be going (at least not at first). I just want to drive my car fast in a relatively safe environment where risk of damage is low.
What you would want to do is increase your air pressure in your tires. Most dedicated autocrossers run 200 treadwear street tires in the street classes. It is not necessary for you to go out and buy new tires until you are sure that you want to to have your car handle better.
If you are going to be doing autocrossing, you may want to get a 4 wheel alignment on your car to certain specs that you can find listed on this site by using the search function.
Most Regions even have ""loaner" helmets that you can borrow if you do not have your own.
The main thing to do is to try it and I can guarantee that you will enjoy it as you stated, "you will have the opportunity to drive your car around various manuevers in a controlled environment.
Again, it sounds fun but it’s not worth destroying my car for.
I went to a SCCA event a couple of weeks ago and road "shotgun" with my buddy in his 06 Z06 coupe. I had a great time, it was a lot of fun and he did his best to recruit me I did walk away knowing that while I had a lot of fun, racing was not my cup of tea.
There is going to be an SCCA Solo at the National Corvette Museum Motorsport Park in October that is being hosted by the Tennessee Region of the SCCA. Would be well worth it for you to check it out.
Look on www.motorsportreg.com under autocross for more info. Registration should be opening shortly.
You're driving around in a parking lot. Yeah, you're doing it fast...but it should hurt a thing. I've been doing Auto x's for 25+ years and never broke a thing doing it. Drag racing? Different story.
I applaud your desire to make sure the car is ready. Here is a link to the tech sheet the St. Louis Region uses: http://stlsolo.org/sites/default/fil...CH%20SHEET.pdf. You can also check out Solo Tech 101 from SCCA for some more info. The whole point of autocross (solo) competition is to wring your car out in a safe and affordable way that doesn't require a ton of special equipment. You and your car will be fine.
At your first event, don't worry what times others are running. For a lot of first-timers, just learning to see the course is the big challenge. The only runs you're competing against are your previous runs. Look way ahead on the course - much easier said than done, btw. Also work on car control - managing the car once it goes past one or more limits. If you spin or hit a cone, who cares? If you aren't a little bit past the limit at times, then you can't know where the limit is. If that region has any guided course walk-throughs for novices, do that. Ditto if they have instructors who ride through with novices and/or let novices ride with them. Ride with as many people as you can, and compare/contrast their runs. If you get bitten by the bug, you'll still be working to improve your driving until your dying breath.
Keep coming back! Nobody gets good in their first event, and usually not in their first year. Spend the rest of this year just learning the classes you can possibly compete in, and what mods are allowed and what aren't. You can start gauging how interested you are and what mods you're willing to make. Tires are always the most important mod to the car, but they are expensive. For now, just keep your eyes open and learn as much as you can. Oh...and have fun!
I did have a battery go completely dead on me, the plates inside broke off and I had to take it apart at a gas station next to the airport we were running at (thankfully some other autox'ers were there, since i had no tools), and they took me to autozone and back to fix it.
I did run the car hot several times, saw my brake fluid boil at one, so pop the hood if its a hot day whenever your laps are over.
I do have a spare set of wheels, would it be smart to get a 2nd set of tires just to use for these events? I mean, that's expensive for sure, but just something I was thinking about.
Thanks again for all the advice!
I want to add some caution here about AutoX.
One of the clubs in my area was a bunch of regulars, they didnt like newcomers.
they were unbelievable competitive ((IMHO bc they failed in life somewhere else).- if you asked one of them what air pressure they ran they either wouldnt tell you , or would tell you wrong info to mislead you.
they were always trying to get each other diaqualified by claiming that their competitor had an ‘illegal mod’ or ‘inadequete safety equipment’
They also would attempt to make the course confusing, with a minimal amount of marker cones. It was basically so a novice in a corvette was going to make some mistakes and not beat their experienced guys in miatas.
this group was the akron sports car club which i believe is now defunct.
Interestingly , i autox’ed with a porsche club (i expected the worst), and found everyone there to be great.
I am hoping that whatever club you race with is not like the first one i described.
i would road course race with the corvette specific clubs, and found that (with the exception of 1 or 2 bad apples), the group members were much more helpful to newcomers.
good luck !
ive seen some pretty crazy things happen at autox (in youtube).
id rather hit a tire wall at nelson ledges road course (which is fully lined with them) vs a curb or light pole at autoX
