Which Clutch kit
EDIT: I reread…you mentioned that you feel the stock pedal is heavy and you are trying to go lighter. I would agree that RAM would be similar to stock.
I am very sorry for any confusion I caused. C4toC2, let us know what year and transmission your C4 has so we are sure we are on the same page.
Thats correct, I feel Centreforce has a much lighter pedal than Stock. All mine are single plate. Im assuming pedal and grip would be improved with the dual clutches, but they've always been outside my budget.
I agree the RAM is about the same as Stock.
But, its not really accurate answering generically, as the pedal effort is gonna change dependant on which clutch tier is selected. The typical Street/AutoCross/HPerformance models built to 450HP are likely similar to stock. If selecting models for higher HP cars, they'll be built with higher clamping force, to match their application, and likely have a harder pedal. Depending how much is done with pressure versus pad compound. Ive driven Vettes with RAM and MCleod before, but obviously not every model.
Matt,
My Vettes are all 85,86,87. But my race Vettes had been converted to ZF6.
Im not sure on availabilty/options of ZF era pull clutches, you'd know better than I.
The Centerforce isnt low cost, but it is one option thats available, and has quality manufacturing.
The Centerforce DF matches up well with a ZF, both being rated to handle 600HP or so.
Im not convinced the Centerforce Dual Friction compounds are anything special over other manufacturers, although appropriately selected.
But their clutch design is unique.
I have a 65, 327 coupe with mechanical clutch linkage. With the practice I have had lately, I can pull the clutch in about an hour. It still is a pain in the *** and putting it back together always takes longer.
I owned Camaro(s) in the 70 - 80' and never had problems like this. If you were careful and put things together correctly, things just worked. From recent experiences with the 65 corvette, we seem to be challenged to attain quality parts in may areas.
Regarding the pivot ball, it is adjustable, is adjusted longer than stock and was required because my steel flywheel is "thinner" than the original. I set is up so with correct free play, the clutch free play adjustment is in the middle of the threads on the clutch pedal rod. I would agree with tdereggi's statement above that at initial engagement the clutch is trying to grab, the disc springs are compressed and then it lets go. I have been tempted find a hill and hang/hold the car on the hill with the clutch and burn it a bit, (who knows, it could fix it). If the issue is indeed non uniform pressure from the pressure plate as I believe, the burn spots will show up on one side of the pressure plate/flywheel -and I will need to resurface the flywheel again.
I am considering the center force option at this time but I will call them. I need to understand a bit more about what is "special". Years ago, stories of flying weights scared me off, and I went with Mcleod.
The key to the light pedal is the ball bearings, though. Not only does it create a low friction pivot point, but more importantly the ball bearings allow the pivot point to change, so greater leverage can be used to add mechanical advantage. You can increase clamping pressure, and then use leverage to reduce that pressure at the foot.
https://www.centerforce.com/articles/technology cu 3/5: street clutch technology video talks about it briefly.
At the end of the day, if leverage isnt being used, increasing clamping force will increase pedal effort. And if pedal effort is reduce, you can be assured the clamping force is being reduce.
So if someone doesnt have a demanding need, they can buy a weaker clutch to reduce their pedal. Or if on budget, a cheap stock clutch is just fine. Simpler designs have fewer components that could fail, so if someone has a high load demanding need, like a high HP drag car, I certainly see the benefit of buying a simpler design clutch. Or maybe someone has strong legs, and doesnt care about pedal pressure. Could also be solved by redesigning and changing sizes of master and slave cylinders to gain the mechanical advantage though hydraulics. Or could use a longer pedal to increase leverage. Better grip can be solved with pad compound, but that has side effects on smoothness and loudness. For street cars, smoothness and quietness is important. Or can just pay a few more dollars, and just get the Centerforce DF, which was designed to reduce pedal effort without compromise, and be done with it.
This is what I found.
Mcleod Street Pro
1. very smooth
2. Great engagement and release
3. around 62 pounds max actuation pressure measure at the pedal.
4. Pressure plate weight is about 16.5 Lbs
5. Nicely made
Luk
1. Does not engage uniformly and chattered/shook the car, engagement marks only on one part of the pressure plate
2. engage/disengagement is fine
3. around 50 pounds max actuation pressure at the pedal
4. Pressure plate weight is about 13 Lbs
5. not as nicely made but it also only cost $100 for the whole clutch kit
Centerforce 1
1. very very smooth
3. around 42 pounds max actuation pressure measure at the pedal.
4. Pressure plate weight is about 17 Lbs
5. Nicely made - close to
I found that I could not use the factory "Flange bolts" with the Centerforce because of clearances around the mounting holes. I went with std grade 8's and lock washers.
Each of the three clutch required a different height for pivot ball adjustment.
My Fly wheel is a 30lb steel - runout is .005"
My disk is an organic made by Hayes
The clutch linkage is factory 65 corvette lever system, set on the "non race position". Everything is greased
Throughout bearing is a all steel unit with a "semi floating" actuation surface.
I would not mind the Mcleod if I had not ruined my knee playing soccer years ago. The 20 Lbs difference in pedal effort is the decider.
