Loosing my mind!
lights all work when headlight switch is on.
left turn signals work fine.
right signals when turned on, after 5 sec or so, blows the fuse.
new bulbs put in, new flasher put in.
when turned on you can hear flasher working, neither the front or rear, light at all.
volt meter goes up and down.
any help?
Normally, when we say "grounding problem", we're referring to a potential poor connection of the return path (ground). A poor connection to "ground" will not cause a fuse to blow.
