Unremoveable Pinion Gear
Old Sep 5, 2018 | 09:55 PM
SnorT91Man's Avatar
SnorT91Man
Default Unremoveable Pinion Gear
Fellow Vetters:
Have any of you ever had a Dana 44 with a pinion gear that couldn’t be removed? I bought a used unit to put some big gears in, and the transmission shop could not press out the 3.45 pinion gear. The fellow who owns the shop says he’s never seen that before! So, now I’m stuck with a stock rear end that I have no use for, unless one of you knows a secret trick to remove it!
Thsnks in advance.
SnorT91Man
Old Sep 5, 2018 | 10:32 PM
jv9999's Avatar
jv9999
If it were mine, I'd put it in the oven and heat it to about 250 degrees to expand the case and then drive or press the pinion out. What have you got to lose?
Old Sep 5, 2018 | 10:54 PM
Kevova's Avatar
Kevova
What did the ring gear look like? Dull gray bearing is stuck. A little heat on the bearing and a press might get it apart. Black and burnt bearing could have welded itself to pinion. It still heat bearing and a larger press.
Old Sep 6, 2018 | 07:55 PM
SnorT91Man's Avatar
SnorT91Man
Default Clarification
The differential was full of relatively clean oil and the pinion turned freely when I removed the batwing/cover. However, it sat around my shop under a blanket for several months before I took it to the transmission shop. Even then, the pinion and ring gear still turned easily. The tranny guy said it was a great shape with little wear, but there were signs of an old wasp nest inside the carrier! There was no discolorization of any of the gears. Anyway, the overall condition didn't warrant breaking the housing to remove the pinion. So, any more ideas?
SnorT91Man
Old Sep 6, 2018 | 09:43 PM
Kevova's Avatar
Kevova
A little heat on the bearing and a 10 ton press shouldn't damage housing. Provided bearing is just stuck. Once pinion breaks loose from the bearing, the pressure required to continue to move pinion drops substantially. If you have a really big drill press, drill a hole through bearing race as close as possible to pinion. Try to split bearing race. You could call a heavy truck or equipment shop. Industrial machine shop for ideas.
To Unremoveable Pinion Gear
