how can i improve on this setup!!!!
Old Oct 24, 2002 | 04:46 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default how can i improve on this setup!!!!
ok this is what i have- i have an 85 with a 383 motor the crank is cast.My heads are stock with 2.02/1.60 with rollers rockers(1.5) and sum porting.My intake is stock,i do have a 58mm(bbk) TB and ported out plenum.i have a FPR set at 43 psi.I have a gutted MAF and an ED WRIGHT chip. what i was wandering what can i do to make this motor alot more poweful.I know heads and intake!! But i want you opion on what you would do /or use!! I want to make 450hp at motor i know this is possiable!! Also my cam is a comp cam 477/480 lift and is 110CL
adv lift i think is 224/230? let me know what you would do JAY
:seeya :chevy :D
Old Oct 24, 2002 | 05:12 PM
vader86's Avatar
vader86
Default Re: how can i improve on this setup!!!! (jparr)
AFR 190 heads or some 88-91 Corvette D-port heads, with 1.6RR. Full headers and catback.
Superram and Accel 219 cam, but that current cam should work with it.
Youll have that HP.
[Modified by vader86, 4:13 PM 10/24/2002]
Old Oct 24, 2002 | 05:34 PM
jmr302's Avatar
jmr302
Holy crap Jay! We have almost the same motor!
Mine isn't based on an L98 longblock. We have the same Comp Cams flat tappet cam but I have 1.6:1 rockers. My static compression ratio is also at least 10:1. I'm running 'as cast' Dart Iron Eagle cylinder heads with 200cc intake runners and 64cc chambers. My plenum is ported to match SLP runners and a 58mm BBK throttlebody (waste of cash). I also have a Superram lower intake and FMS 24lbs/hr injectors.
I recently dyno'd the car and it made 380 hp @4500 rpm and 504 ft-lbs @3500 rpm at the flywheel. This is with a vacuum leak so I think the final numbers will be higher once that is resolved. I shift at 4700 rpm and there's no point in revving it higher.
Have you considered nitrous? That's the cheap n' easy way out. I suppose we could start another SR/MR debate. They both cost $1300. I'd probably choose the SR to keep it torquey and help the top end. If you have metal or fiberglass fab skills then consider the Stealthram.
I'd go with aluminum heads if I was redoing my setup. Less weight, greater octane tolerance. I bought these particular iron heads because they flowed well and were cheap. AFR's are nice but cost twice as much as my heads.
You didn't mention any exhaust mods. I'm running 1-5/8" primary headers, hollowed out cat, Borla Y-pipe, and Borla mufflers (inherited these--don't buy them!).
Old Oct 24, 2002 | 08:35 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
ttt
Old Oct 24, 2002 | 10:53 PM
ZD1's Avatar
ZD1
52mm throttle body
I'd say the Superram over the MR with your cast crank, MR is feasible if you've internally balanced the internal but probably not for MR/Nitrous combo's
To how can i improve on this setup!!!!
