Crank, no start.. open ignition wire??
Old Sep 9, 2018 | 10:53 PM
Mitch7's Avatar
Mitch7
2nd Gear
Default Crank, no start.. open ignition wire??
92 LT1 Auto. Started with asr service light, getting codes on module 9- H62, H64 for long time now. Tach pulses falt. The tach would spike intermittently when it warms up above 3-4k rpm. Then sometimes the motor would shut off going 40 mph...Trying to figure it out,( I'm thinking there has always been a shorted wire) I was playing with the wiring harness behind the motor looking for damaged wire or bad connection. Now, go to crank the engine - crank but no start. Im thinking I broke the bad wire & I might have an open now ? Somewhere on the ignition wiring possibly? I have a cheap multi meter, a test light, and a hazzy understanding of electricity. Can someone please help? Where do I start? getting overwhelmed!
Old Sep 10, 2018 | 09:12 AM
JimLentz's Avatar
JimLentz
To me it sounds like one of two probable issues, either a problem with the Optispark or a faulty ECM.
Old Sep 10, 2018 | 10:37 AM
Mitch7's Avatar
Mitch7
2nd Gear
Opti is only 6 months old. Was running good & no bad Opti symptoms. ECM is not throwing any codes, I think it's still fuctioning properly..
To Crank, no start.. open ignition wire??
