service ride control light is on
Old Sep 11, 2018 | 08:10 PM
duramarc's Avatar
duramarc
3rd Gear
Default service ride control light is on
seems to be no difference in ride
Old Sep 11, 2018 | 10:37 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
If you service ride control light is on, the system will automatically default to the "tour" setting and will no longer adjust, so every setting will feel the same.
You will need to find your faults. Just jump the A & C on your ALDL and follow the codes in the DIC. If you do that, you will know your problem in less than 2 minutes.
Old Oct 7, 2018 | 12:05 PM
duramarc's Avatar
duramarc
3rd Gear
Thanks you made that sound easy...but I didn't understand any of that can you explain a little more?
Old Oct 7, 2018 | 12:50 PM
billschroeder5842
https://www.corvetteactioncenter.com/tech/c4/fx3/
You might want to spend a few minutes on these links.
Also, your FSM is really pretty good about troubleshooting.
Old Oct 16, 2018 | 08:52 PM
duramarc's Avatar
duramarc
3rd Gear
fsm is that the brain box that runs the ride control?
Old Oct 16, 2018 | 08:54 PM
billschroeder5842
Field Service Manual. This factory repair manual is the most important purchase you can make after your car. It is really the best reference guide for troubleshooting and repair.
Old Oct 31, 2018 | 04:09 PM
mixalive's Avatar
mixalive
You can turn that indicator light off by disconnecting the connector in the ABS panel behind the driver seat.
To service ride control light is on
