1990 a/c
Old Sep 14, 2018 | 08:31 PM
dennis m's Avatar
dennis m
Default 1990 a/c
my a/c compressor will not engage Freon is good, the radiator fan is to turn on when a/c is selected .so if the fan wont turn on will that stop the compressor from engageing
Old Sep 14, 2018 | 09:42 PM
ChumpVette's Avatar
ChumpVette
Pressure switch.
Old Sep 16, 2018 | 09:07 AM
bosshog8's Avatar
bosshog8
There are 2 pressure switches. If you have climate control and a low freon condition was detected from either of these switches (because the switch/switches are bad or there was/is low freon) then you have to do a system reset before it will turn the compressor on again. You can remove the 10 amp radio fuse and 15 amp courtesy fuse for 15 seconds or disconnect the battery for 15 seconds to reset it.
To 1990 a/c
