Have an 1989 bought BBK billet fuel pressure regulator.?????
Own a 1989 automatic coupe. Having this BBK billet fuel pressure regulator. What do I need to do to use this. From what I am seeing the lowest pressure is 30 or 35 lbs. My car is supposed to use 23lb injectors. Question is what can I do or need to do to utilize my purchase. Appreciate any help. Thanks you all for your consideration. KC
St. Jude Donor '17-'18-'19-'20-'21-'22
That is the correct one. Rating of the regulator is for pressure at fuel rails which should be around 42 psi. Your injector rating is the pounds per hour usage rating (amount of fuel).
